Please HELP!! HG and valve springs??
Old Nov 4, 2007 | 07:53 PM
thewished's Avatar
I have seen a lot of trucks with these and what do they do for you?? Let more exhaust out? My HG is toast I think, I'm smelling coolant, my gas pedal is hard to push (maybe from afc spring not getting enough boost?) Coolant is puking from the passenger side in the front of the motor.. (water pump maybe??)
Old Nov 4, 2007 | 08:10 PM
dieselman2300's Avatar
Get the head surfaced and magnafluxed for cracks. If it needs a rebuild have themdo that. You can intall 60# springs, they usually go for $10 a spring x 12.
Put a "marine gasket" in that is the appropriate thickness for how much they took off the head.
You can install studs too, if you want. At least get new head bolts.
Slap everything back together and go.
Old Nov 4, 2007 | 08:12 PM
stuckey200224's Avatar
the valve springs keep your boost or drive pressures form pushing the valves open when there not supposed to open you definatly need these if you intend on increasing the rpms above stock. not sure when they become nessary due to excess boost.
Old Nov 4, 2007 | 08:15 PM
Everyone says you dont need the 60# springs until 3700 rpm or more. For the $120 is cheap insurance.
I always thought I didnt need them until I took the head off and found #6 ex. pushrod to have a dogleg in it.
Old Nov 4, 2007 | 08:34 PM
thewished's Avatar
Thanks, so they are stronger than stock? or just new?
I am completely and uterly broke after the $4k tranny... I need a crankseal and a timing cover and a vacuum seal... Anyone wana trade a sound motor for mine??? I'll throw in a dented up bed...
Captain
Jun 25, 2008 04:40 PM
53 willys
23
May 19, 2008 06:14 PM
12valve
Mar 11, 2008 10:57 AM
SuperiorRam
Mar 15, 2007 03:10 AM
bigragu
Jul 12, 2005 07:11 PM
