Play time
Play time
Just some recent observations since I have a clutch that holds now
1st gear I can hit 14 lbs, 28 in second, 45 in third on up. Let me tell ya- never seen fp hit 12 and I've only seen 1200 egts once @ 100+ The only time the rear four break loose is high rpm launches in 2nd or third.
I've made it through all the odd smarty settings plus one even SW. The higher settings don't seem to make the truck more responsive as much as it just creates low boost smoke. Lets just say less than 10 lbs of boost + full throttle = a bad day for a tailgater. Smarty really lets you ride the line between clean power and black smoke- so you can let out a little haze and people will tend to stay back
Anyways I think I'm done with 9 and am going to go back to 5. Maybe test 3 again. SW1 was really clean, but didn't improve my mileage compared to the other sw's so I might as well have fun =P
Can't wait for the 29th
Wish I could make the 22nd too =(
Anyways I think I'm done with 9 and am going to go back to 5. Maybe test 3 again. SW1 was really clean, but didn't improve my mileage compared to the other sw's so I might as well have fun =PCan't wait for the 29th
Ouch. Your not hitting full boost till 3rd? I'm glad I've got an auto. Full boost as soon as the trans slides into 2nd.
I'm getting $700 back from the government and I was gonna put that towards the smarty but I figured that I might as well get the trans done first so I can have even more fun with the smarty. How long have you been running on #9? It took me a couple of days to get used to the difference in throttle response when I was running the full catcher. When I first installed it I noticed that it was different but I never realized how much different. I definately noticed it when I tried to set the cruise though.
Ugh, I'm jealous.
Ugh, I'm jealous.
Originally Posted by Phatboy
....I've made it through all the odd smarty settings...... The higher settings don't seem to make the truck more responsive as much as it just creates low boost smoke.
It is, however, true that all odd # settings end up in the same place (probably around 2200+/- rpm). Higher setting just bring in the fuel earlier.
Maybe differences are more noticable with an automatic?
Your HRVP has to make the smoke harder to control? Having to wait for 10 psi boost, before you hit it hard, is usually an automatic thing...at least it is with a bigger turbo
RJ
I run out of rpms before full boost builds.
RJ
RJ
I ran 7 for a couple weeks then went to 9 for the last couple weeks and am not seeing a huge difference so its back down to the lower sw's for me. My best mileage to date was on sw7 fwiw.
I'm with Phatboy on this one... although I haven't tried the other settings, SW#9 will lay down a cloud anytime you're running low boost. I'm also running DD3's. The truck is most responsive by rolling into it until you've got some boost and then getting all over the throttle.
soulezoo
47
Jun 27, 2008 04:25 PM
k_butz
Feb 23, 2007 03:42 PM
Geico266
Jan 20, 2007 03:12 PM
taken5875
20
Jan 11, 2007 09:38 PM
