Performance Help for a 2002 2500
Old Mar 14, 2006 | 10:52 AM
DieselRook's Avatar
I am trying to help my friend out he just bought a 2002 24v and i was just wanting to know what you guys thought would be some good starters besides exhaust chip intake and gagues. Who makes a good chip i have heard good things about the TST but was just wondering if there was anything better
thanks for your help
Old Mar 14, 2006 | 11:06 AM
HP Upgrades's Avatar
Edge EZ
Edge Comp
soon Edge Juice
soon TS Performance MP-8
van Aaken power module
Thats a start!
It will depend on what level of performance he is looking to get, and what he use's the truck for the most as which direction to go.
Old Mar 14, 2006 | 11:09 AM
RowJ's Avatar
Welcome to DTR!
If I could only add one power enhancer... It would be the Smarty. Only adds 60 hp but the drivability improvement is so much more!
http://www.madselectronics.com/index.html
Starting with gauges is best way to go so you have base line readings from which to measure all future changes.
RJ
Old Mar 14, 2006 | 11:52 AM
Jaxn51's Avatar
Just installed a van Aaken V-5 and love it. Nice power boost for general driving and towing. Wakes it right up and not expensive to purchase. $400 thru Ebay.
Old Mar 14, 2006 | 12:12 PM
DieselRook's Avatar
he stricktly wants it for performance he tows very little and wants the most out of it. Does anyone like the TST box?
Old Mar 14, 2006 | 12:41 PM
Mike D's Avatar
TST is a great fueling box, stacked with a Smarty or Edge EZ he can build some nice power.
Old Mar 14, 2006 | 12:46 PM
Beast2B's Avatar
just remember that it won't take more than ~50hp to hit the limit of the auto trans. A bit more for the manuals, but they have a fairly low limit as well.
Old Mar 14, 2006 | 12:56 PM
mcoleman's Avatar
What beast just said goes for me to.
Old Mar 14, 2006 | 01:21 PM
John_P's Avatar
Diesel Rook:
Welcome to the website!
The other DTR Members have given you some good advice! To add to what has already been said, I have a TST PM 3 (Competition) on my 2002 Dodge CTD and love the thing! IMO,....Mark Chapple @ TST builds one of the best performing fueling boxes for our trucks in the industry! But as some of the other members have said, the "Blue Chip" and Edge Boxes are good too.
I agree 100% with what DTR Member "Beast2B" told you about the auto transmission on the Dodge CTD trucks though. They are pretty weak stock and IMO need to be "beefed up" BEFORE adding any fueling boxes! The manual transmissions aren't much better. Also, before adding any fueling boxes tell your friend to be sure and install a set of good quality gauges with AT LEAST fuel pressure, boost and pyrometer (EGT) unless he buys a fueling module that already has that included with their unit.
Good luck!
John_P
Old Mar 14, 2006 | 07:40 PM
sammy340's Avatar
Originally Posted by John_P
Diesel Rook:The manual transmissions aren't much better.
Do you mean the clutches? The NV 4500 seems to be a very good tranny for power.........
Old Mar 14, 2006 | 07:43 PM
Beast2B's Avatar
I am talking about the clutch. The NV4500 is stout, but the 5th gear nut can be an issue (I've read about it, not experienced it).
Old Mar 14, 2006 | 09:48 PM
John_P's Avatar
sammy340:
Yes, let me clarify my statement,.....I also meant the clutches in both the NV4500 (5-speeds) and the NV 5600 (6-speeds). They will take the abuse from say a TST PM 3 on levels 5-9 for awhile, but eventually they will give out.
Sorry about that..............................
John_P
Old Mar 14, 2006 | 11:06 PM
one54ton's Avatar
I'd say start with an Intake system, 4 or 5" exhaust and an Edge Comp or a TST box stacked with an Edge EZ. This should be a very good starting point.
Old Mar 15, 2006 | 10:47 AM
diesel_burner's Avatar
Go with Twins and mach 6's and edge drag comp. That should be a good start. GO BIG OR GO HOME.
Old Mar 15, 2006 | 11:03 AM
seabee's Avatar
burner not every one is up to spend that kinda money right off . plus you didnt say anything about the head studs and fire rings that go with those fun toys. but i agree if we are going for big fun go way big and dont look back . but fist things first gauges and throw out the stock lift pump .
