Ottomind Question
Old Nov 21, 2009 | 11:56 PM
srose3070's Avatar
Ottomind Question
I am new here and i appreciate the topics I have read so far. I have a Banks ottomind. I believe it to be somewhat older version. I have no switch or adjustment on the box what so ever. I would like to know if it is possible to run a programmer in unison with the ottomind or would I have to remove and start all over again? I would like to have a bit more HP I am not wanting to groundpound or anything a slight increase would be acceptable. If this would work could someone recommend a programmer I could use? I would like to see around 50 to 75HP increase. If a module would work with this setup better I would be open to that as well. I appreciate your time and thanks for looking.
Old Nov 22, 2009 | 02:49 PM
Crazydave's Avatar
The Ottomind is a mild fuel box with no adjustments. I ran an edge ez stacked with one, with great results. I would recommend snagging a used ez off the classifieds and trying that. They are pretty inexpensive used and you can usually get your money back out of it if you don't like it, that or get a quad xzt. It is another timing box you can stack with it, but it has more options and has adjustable on the fly power levels.
I stacked like this
MAP Sensor to banks, banks to EZ, EZ to factory harness for the map plugs. Then the other ez plug to the can bus. And on the Ottomind it has TPS plugs on it, i just hooked them into themselves and and not to the truck.
This should help with mileage as well and if you need a little more punch, RV275's are pretty cheap and i made 370 RWHP 837tq with that setup and injectors.
Good Luck
Old Nov 23, 2009 | 09:46 AM
srose3070's Avatar
Thanks a bunch. I had no clue about the ottomind at all. I looked up both the EZ and the Quad and that is about the HP rating I would like to see I don't want to tear anything up. I may at some point decide to upgrade further. You were a great help.
Dusty Ratcliff
Feb 20, 2007 02:31 PM
Dusty Ratcliff
Feb 19, 2007 09:17 PM
Dusty Ratcliff
Feb 12, 2007 11:38 AM
CTD_Neil
May 12, 2004 05:42 PM
