One for the pre 01 Dually owners....Tires
Old Dec 19, 2003 | 06:24 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I know that in either 00 or 01 they changed the offset on the dually rims.
My questions are:
How many are using 235-85-16 on the earlier trucks?, and is anyone having a clearence problem on the rear (between the tires)?
I want to go up a size from the 216s but don't want to create a problem.
I don't tow often, and then it's usually only a motorcycle trailer. (maybe 300# tongue wt).
Old Dec 19, 2003 | 06:42 PM
SolidJunkMM's Avatar
Re:One for the pre 01 Dually owners....Tires
I am running 235 85's on my 97. I have had no clearance problems and have towed as heavy as 30k gross.
Go for it!
Joe
Old Dec 19, 2003 | 07:00 PM
Ramflasher's Avatar
Joe...have you chained up with the 235s yet? I have stayed with 215s on my '99 cause I am worried about that... ???
Old Dec 20, 2003 | 05:01 AM
Not many people here run chains. Myself included. Chains would probably be tight though.
Joe
Old Dec 20, 2003 | 05:33 AM
sherod's Avatar
I'm running 235/85 on my 98. No clearance problems at all even when loaded. Now for the bad news... Unless you can find a set of true dual chains, you are out of luck. Even cables are too tight. I am considering going down to 215's because I do need chains now and then.
Ed
Old Dec 20, 2003 | 05:49 AM
Shovelhead's Avatar
Thanks for the replies folks.
;D 235s it is ;D
The only chain I deal with is on my '76 Harley.
The "Geezer-Glide" has a belt.
If the weather gets that bad the Landcruiser comes out of the garage. ;D
Old Dec 20, 2003 | 06:58 AM
pappyman's Avatar
I am on my second set of 235/85 16 tires and have not had any tire rubbing even when towing heavy....I do keep my tires at Max inflation pressure even when not towing....the tires did rub once but my trailer was loaded very badly and put almost all the weight on my rear truck axle even then the rubbing was minor
I do use cable chains on my rear tires....not for snow but more offen I get stuck in mud and need extra traction
I always use chains on my motorcycles even my 2002 custom big bore Evo ;D ;D ;D ;D
Mexstan
Feb 9, 2010 10:46 PM
1320
May 29, 2009 10:24 PM
kev94mx
19
Jun 15, 2007 07:33 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
the_fox_man4
Oct 13, 2006 06:12 AM
