which oem turbo has the smallest exhuast housing?
Am I right in thinking that the 03's have a 9 cm exhuast housing?
If so which trucks came with them? 01-04 that kind of information?
Are they the hy35?
Are they the hy35?
I think they're HY-35s, but have 12cm housing... The 9cm housing was perfect for the lower hp 2nd gen autos that had 235hp. But now the stock ratings are 90hp more, and that means you need a little larger housing.
Justin
Justin
pourindeisel, do you happen to know how the cm measurements are taken? You say 12 cm compressor housing? I m used to a/r ratios. Do you happen to know the wheel sizes in a hx 35 or 40? p trim exhuast? 70 mm compressor? that sort of hing?
IIRC, Holset's weird housing sizes are in cm^2. So it's an AREA measurement (square centimeters).
This is probably the cross-sectional area of a slice of the compressor housing taken at a certain point. (maybe 12 o'clock?)
A typical A/R gives you the area and radius, while Holset uses only the area, so maybe they assume a certain radius?
Justin
Justin
SKATERHAULER
Oct 2, 2013 06:34 AM
apwatson50
Sep 7, 2006 03:24 PM
1320
Jun 23, 2003 08:05 AM
