nv4500 to nv5600 convo help
Old Nov 5, 2006 | 02:14 PM
12valveford's Avatar
I need to know if I can use my sb con o clutch with a nv5600 that I was using with my '97 nv4500?
Old Nov 5, 2006 | 05:32 PM
Dusty Ratcliff's Avatar
not unless you had the bigger input shaft in the 4500, or happened to have an ealry 5600 that used the smaller shaft, but more than likely it's not gonna work, Dusty
Old Nov 5, 2006 | 07:54 PM
BCB's Avatar
BCB
he is right. what year NV5600 do you have?
BTW. you will love having another gear! towing or on just daily driving. there is a gear for everything. if you have any more questions feel free to PM me.
Old Nov 6, 2006 | 01:34 AM
so what is considered an early nv5600?
Old Nov 6, 2006 | 01:45 AM
1-5-3-6-2-4's Avatar
99-00 nv5600 had a weaker 1-1/4" 12 spline input '01 on have upgraded 1-3/8" 10 spline.
Old Nov 6, 2006 | 10:21 AM
ok I have my parts man on the search for a 99-00 nv5600
then when I upgrade the flywheel and clutch down the road I will take care of the shaft
what else is different?
trans mount?
slave cylinder?
Old Nov 6, 2006 | 11:30 AM
blackdiesel's Avatar
Registered
good luck. Finding a nv5600 at a good price is hard, finding one with a 1 1/4 will even be harder. not say you can't, just GOOD LUCK
Old Nov 6, 2006 | 12:34 PM
gunracer1's Avatar
well i can tell you, changing the input on a 5600 requires a total teardown of the tranny. i would suggest you send your clutch to peter and get a bigger center hub and use a later model 5600.
Old Nov 6, 2006 | 02:31 PM
BCB's Avatar
BCB
i have to second that.
Old Nov 14, 2006 | 11:16 AM
nates90's Avatar
hey guys, i know this is a old forum..but i had some questions on the topic
tell me if im right.... if i get a mu 13-1.375 con fe and then buy the nv5600 it should bolt right up to my 95 cummins......now another question, what happens to driveshafts....stickshift......4x4 lever......and cross members.....pictures would be awsome....thanks guys
Old Nov 14, 2006 | 11:54 AM
nates90's Avatar
alright, another qeustion also, if i keep my nv4500, what will the 1 1/4" input shaft handle vs. the 1 3/8" input shaft (hp and torque).... because they make a shaft upgrade kit....would i then use the mu 13-1.375 con fe clutch with the new shaft and my nv4500?
Old Nov 15, 2006 | 09:42 AM
Captain's Avatar
from what I understand the upgraded input shaft on a 4500 uses the same clutch as a 5600 with the larger input shaft. So if you upgrade teh shaft on the 4500 you can swap between transmitions. I was told you wont really break 1 1/4" input shaft unless you really try to or have some insane amount of power. As far as switching to a nv5600 you need some parts. a new trans cross member (unless you have a 98 that has an 11" wide cross memeber) a shifter and linkage for the transfer case. Your rear drive shaft has to be shortened and the front one has to be lengthed (good thing since the front shaft is at a bad angle to start with, that angle will be lessoned) I have a dd on order an input shaft for my 4500 but if I can get my hands on a 5600 ill sell the shaft and just upgrade. from what I hear the 5600 upgrade is much nicer to drive. that 3-4th gear gap is terrable on the 5 speed
anyone have a 5600 to sell me? lol
Old Nov 15, 2006 | 08:17 PM
BCB's Avatar
BCB
everything he said is true except if your good with tools you can make the older crossmember work by turning it around, and make the linkage for the transfer case.
Old Nov 15, 2006 | 08:51 PM
Captain's Avatar
Thats handy to know. Saves a lot of money too.
Old Nov 15, 2006 | 11:42 PM
Beast2B's Avatar
what's a 65k mile nv5600 worth with a Southbend ConFE clutch on it?
