not enough boost?
Old May 31, 2003 | 01:42 PM
Lance's Avatar
not enough boost?
so I moved my plate all the way forward, turned the star wheel all the way forward, and moved the housing forward, there isn't that much smoke and boost only goes to 25 psi. whats the deal? how are you guys getting 35+ psi by doing this? <br><br>Lance<br>95 2500 12V
Old May 31, 2003 | 03:54 PM
SjLingenfelter's Avatar
Re:not enough boost?
Bigger turbo's or Clamp wastegate shut.
Old May 31, 2003 | 04:07 PM
dodgeman01's Avatar
I only hit 25 psi with the WG clamped shut and the stock fuel plate slid all the way forward. just a new fuel plate later and 370 injectors and I see 40 all day long. Not really good for the stock turbo but I plan on a different one next year.<br>DM01<br>But I have the 180hp pump so if your is the 215hp then it should pull more boost with the stock plate.
Old May 31, 2003 | 05:47 PM
Farmout's Avatar
I noticed that the hose attached to the waste gate was loose. Will this affect my boost?
Old May 31, 2003 | 06:44 PM
Lance's Avatar
I forgot to say that I clamped the hose shut that goes to the wastegate also.<br><br>Lance
Markal05
Oct 6, 2009 07:47 PM
Boatnik
Aug 5, 2007 09:09 PM
Rollin' Smoke
May 14, 2007 08:46 AM
MDMIKE
Apr 26, 2004 05:38 PM
RDABIKE
Jun 13, 2003 11:26 AM
