New dyno numbers.
MikeD, couple questions, did you let out at 3100 or is that just where it de-fuels at? and does your dyno sheet say corrected or un-corrected? just curious.
I keep hearing that the smarty fuels to 3500?
not sure on HP numbers but a guy at the track friday night had a HRVP44, mach 4.5's, usb bell turbo, and a edge comp running 13.6 with a lifted truck on 36's
i can only imagine what a smarty would do for him
Edit: I called Jeff, he thinks with correction factor their will be around a 2-3% loss with the weather from Friday. He wasn't in the shop, so I'm gong to call him back around 11:00 to get the exact uncorrected HP/TQ.
Phatboy, I would have to look at my past dyno sheets to compare the torque peak. If what you're saying is correct, maybe a lower number on the Smarty will extend the torque?
Add 3% for winter fuel.
Tims truck dropped from 630 to 598 with winter fuel.
Thats 5%, but 3% seems more the average we have seen all winter with various trucks.
So, in the 480 range.
Don~
Don~
Thanks for everyones input. Phil, I might want to use your EZ for the NC dyno event in April. I feel like I'm close with the TST settings, the only varible is the Smarty.
Don~
Don~
Don, How many people do you know that have run the TST Smarty combo with an increase in power over the EZ?
Sorry pal, I finally sold it!! I can probably get one for you though!!
You know I feel the same way about you and I'm telling you that your truck runs just as good as my 2002!
