Need some help for those that know.
Old Jul 27, 2006 | 08:51 PM
BCB's Avatar
BCB
Question Need some help from those that know.
I am looking to build about 550-650 HP in to my truck. I need to be able to tow about 12,000-15,000#'s. But i can valet switch to cut back on the fuel when towing, correct? I would like to have a good truck for the drag strip but most importantly it needs to be a daily driver that can stomp any PSD around.
I have been looking at New Era Diesel's EDM'd 435's, a SPS66(very open to suggestions here) to get stared for now.
What turbo, injectors ect. can get me there and still be streetable?
Yes $ is very important as i am still in school.
Old Jul 27, 2006 | 09:07 PM
cummnz4x4pwr's Avatar
If your wanting to tow with that kind of hp you are going to need twins, a 66 would be waaaaaay to slow for towing imo.
jake
Old Jul 27, 2006 | 09:17 PM
BCB's Avatar
BCB
I plan on going to twins eventuly but for now (while I am broke) i need a bigger single that spools good for towing and you cool EDM'd 370's at least.
Old Jul 28, 2006 | 08:40 AM
RowJ's Avatar
Towing that much weight with a SPS66 would be no fun at all...in my opinion. Not much fun around town in this hot weather either....even empty!
RJ
Old Jul 28, 2006 | 08:41 AM
Gotlift01's Avatar
Honestly at that HP level I don't think you are gonna find anything that spools the way you want it to and still be able to keep you cool while towing. That is a lot of fuel and a big single charger will handle it, but it'll be extremely laggy.
I suggest shooting for the 400hp mark, you'll be able to tow pretty much whatever you want, stay with a single, and still be able to keep cool. Twins would be the way to go, but like you said money is a little thin for you.
What you could do is get the BD Super B turbo for now, and then once you have the money you can buy the twins upgrade kit and have one awesome set of twins. That turbo will get you over the 400hp mark with some injectors and it "should" tow pretty well. I've heard a lot of people really like that turbo............
~Nick
Old Jul 28, 2006 | 08:43 AM
Tiny's Avatar
It is going to take a lot of money to run like you want it to, and still be able to tow 15K lbs. That normally takes two different style of builds. There are guys here doing it, but speed costs money, and towability costs money, so open the check book. I would choose one or the other for now while funds are tight.
Old Jul 28, 2006 | 08:47 AM
BCB's Avatar
BCB
yeah for now i am lookin for 400-450ish area then next year twins and 600HP.
So what would be a good setup for say 425 HP
edm'd 370's
B-1 bomber?
maybe some LC DV's?
Old Jul 28, 2006 | 08:56 AM
signature600's Avatar
Take it from someone who tried to build what you want!!
If you want High HP, AND have to tow that much weight...you WILL NEED twins!!!
I don't care who you ask, a single...any single, won't handle the power, and towing enough to keep EGT's in check!!
If you can't afford to do it all at once, wait!! Do the turbo's first, then start adding fuel! This is much safer than the other way around!
If it was me, I'd start with a BD Super B, HTBG, or something that size for a start...the 62mm chargers don't spool well enough for my liking when towing that heavy. With 4.10's, you might be OK, but it won't be fun!
Then, hang a B2 under it for support...you should have enough air to get over 500, but 600would be rough with a stock head and cam on a 12v...and still be able to tow! On my old truck, I was going to do what you are wanting, but I was going with a fully ported head, and cam!
Another thing is timing...for towing, 16-17* is as far as I'd go...especially with twins! To make 600hp, it's gonna take more than 17* of timing, probably closer to 20*! Another tradeoff!
You just found the nicer thing about the newer trucks...Better head flow (when stock), variable timing, and more adjustable power control!!
IMHO,
Chris
Old Jul 28, 2006 | 09:03 AM
BCB's Avatar
BCB
Thank you Chris, do you know of somewhere that has a good price on a BD Super B or HTBG? PDW?
Old Jul 28, 2006 | 09:25 AM
Gotlift01's Avatar
Pretty much anywhere you look they are all about the same price give or take a few bucks. PDW would be a good start, they're good guys over there.
~Nick
Old Jul 28, 2006 | 09:35 AM
~Nick
I would start there...Doug is a pretty good guy to deal with from what I hear!!
I was also going to call Industrial Injection, and see if they had anything that size, with their upgraded bearings and usual mods. I never got around to that, so you might give them a call too! OR Doug @ PDW might be able to answer that for you...He sells their chargers!
Old Jul 28, 2006 | 09:46 AM
Tiny's Avatar
Doug is a great guy to work with, and he will set you straight on what charger would work well for what you are looking to do. Good luck.
Old Jul 28, 2006 | 10:02 AM
12valve's Avatar
I PMed you for a place with a good "HTBG Turbo" price or any other HTB2
Old Jul 28, 2006 | 06:04 PM
BCB's Avatar
BCB
thank you for all the help and the PM 12V
keep the input coming.
Old Jul 28, 2006 | 06:17 PM
high country's Avatar
before you spend all your cash on a charger you may want to think about a clutch.
