need quick answer on pacbrake!
Hey guys there's a pacbrake eb for sale near me for 500 bucks and id like to get it but the guy says its for a 98-02 or 24 valve. will this work on my truck or is there a difference between the two? the turbos r the same I think. any reason y it wouldn't work? needs answers n ideas quick before the deal disappears. thanks in advance y'all
Both units use vacuum to operate. That said, the newer unit uses pin 20 on the ecm to control the vacuum solenoid relay. Basically you let off the throttle and idle validation turns the brake on.
On the older truck, you'll need a micro-switch for the clutch, and perhaps one for the throttle as well, to allow you to control the brake. Both units will need a power switch that is dash mounted, to control the master power.
Great. that being said will it work on my truck? are all these micro switches readily available some place so I can piece it together? Sry I'm a complete noob in this topic.....
Best thing to do is contact PacBrake directly, and ask them about parts. They have really good customer service, and are always willing to help.
I haven't looked at the 12 valve trucks in a while now, and can't recall if the brake bolts on the same way or not. I know on the 24 valve trucks, you replace the entire rear plate and elbow assembly.
When I bought my Pac brake they said the diff. is that the 24v engine uses a 60 pound valve spring. the older 12v uses a lighter spring. So you might need bigger springs or see if Pac brake has a different butterfly valve for the brake you are buying. That you won't over load your valve springs.
I would like to install a Pac brake as well on my 2002 5.9, do you HAVE to replace the valve springs? The reason I ask is I believe I could install the pac brake but the exhaust springs might be too much of a job for me.....
The 24V Cummins already has the stiffer springs.. Install at will!!
pwrtripls1
10-14-2005 08:57 PM
Buckshotmckee
07-07-2005 05:06 PM
Mopar_Mudder
19
05-16-2003 07:34 PM
