need pyro help!!
Old Apr 15, 2004 | 08:59 PM
apache's Avatar
need pyro help!!
What is the correct thermo coupler depth for my r650 Issopro set up? I dont see anything in the instructions about this. Any help would be great.
Thank You all.
Old Apr 15, 2004 | 10:29 PM
slim51015's Avatar
I set mine about 3/8 of an inch in.
Old Apr 15, 2004 | 10:34 PM
dodgediesel4x4's Avatar
Just make it deep enough so its not touching the underside. I'm assuming you're going pre-turbo, so after you drill and tap into the manifold, just make it deep "enough" to where its not touching the underside. Good luck,
Hunter
Old Apr 16, 2004 | 09:46 AM
apache's Avatar
Thanks guys, I spent some time looking in the search zone and found a .3 to .7 of an inch dimension, I set it in .5. works great so far. was unsure about adjusting the thermocoupler. Issopro catalog does not list a R650 as adjustable, but I loosened the upper nut and pulled it up. It was pretty stiff at first ,the ferruel was holding it in place.
Old Apr 16, 2004 | 07:32 PM
duner's Avatar
spoke with technical at isspro and they said that they did not have a recommendation as to location, up to the buyer. also said that the probe should be inserted to the middle of the tube or runner.
Old Apr 17, 2004 | 01:13 AM
KATOOM's Avatar
As said earlier, adjust it to be in the middle of the runner.
Old Apr 23, 2004 | 08:59 AM
jthorpe's Avatar
DTR Founder
Not an emergency, moved to the appropriate section from the help section.
smokey94
Nov 11, 2024 07:39 AM
dieselJon
Mar 5, 2007 07:39 PM
06Cummins
May 23, 2006 03:31 AM
NoSparkplugs
Aug 29, 2005 10:31 PM
GreyBoy
20
Nov 1, 2003 03:47 AM
