Need pictures of lazarlinks installed
Old Apr 29, 2011 | 03:31 PM
vp dually's Avatar
I would like to see them installed on your 2nd gen.Thanks
Old Apr 29, 2011 | 03:40 PM
Doj Dewd's Avatar
i don't have pics, but what would you like to know?
Old Apr 29, 2011 | 03:43 PM
vp dually's Avatar
I would like to see the bracket installed
Old Apr 29, 2011 | 03:48 PM
vp dually's Avatar
When i put the bracket on the bolt then the slidenut then the link,another slidenut slide it in the factory hole the bolt does not go in all the way.the tapered edge of the bolt should protrude through the factory hole.
Old Apr 29, 2011 | 03:49 PM
Doj Dewd's Avatar
oh ok, i do not have that installed. i have 'been meaning to get around to it' for at least two years now!
it would be very easy to install. mine needed to be drilled, but if i were you i would weld it if possible.
so the current links, or the lazarlinks without the bracket basically make a 90* bend right? well, with the brackets it turns the 90* 'L' into an upside down 'T' for two solid mounts instead of one single mount.
not sure if you knew this already, but thought i'd mention it for others anyway . . .
Old Apr 29, 2011 | 03:53 PM
Doj Dewd's Avatar
oh, i see you have another post. didn't know you had already tried to install them.
well, i had mine on with the drill method for a while but i didn't have it lined up quite right so i took them off and have been meaning to weld the hole closed and then just weld the brackets on instead of drilling next time.
i do recall having issues as you are mentioning though and i just had to play aruond with the nuts/washers/spacers until it all worked right . . . i even called mike and he said they ship them in the correct order/configuration but i already had them on the floor in pieces . . .
Old Apr 29, 2011 | 04:01 PM
vp dually's Avatar
Even if i skip all the washers it dont jive.I would weld it if it would line up.Plus it would give me a reason to repaint this gay blue bracket.
Old Apr 29, 2011 | 04:08 PM
vp dually's Avatar
If i can find another bolt with a longer taper it would be nice and snug,then i could use the bracket.
tauberson
20
Apr 28, 2008 01:19 AM
drewallen42
67
Apr 11, 2007 10:59 AM
Rancho71
15
Sep 1, 2005 11:55 PM
Mopar_Mudder
May 1, 2004 08:28 AM
