need help with TST stack
Old Dec 20, 2006 | 08:57 PM
inline6power's Avatar
can someone please draw me a diagram on how to stack the drag comp(EZ MODE) with the TST comp. my buddy in idaho just baught this combo,,well came across this combo and he dosent believe me when i tell him how to hook it up. he wants more than one person besides me to tell him how to hook the to up. thanks for your help guys.
Old Dec 20, 2006 | 09:16 PM
judge88's Avatar
tst goes into the map sensor first then ez into the tst then ez into the other end of map sensor plug.
motor-------------tst-------------ez-------------plug that was oringinally into map sensor.
Old Dec 20, 2006 | 09:19 PM
rockjeep73's Avatar
What he said. Thats how mine is hooked up and works great.
Old Dec 21, 2006 | 02:47 AM
man thats what i keep tellin him, now that you guys say the same thing mabey he will listen to me. thanks guys.
Old Jul 23, 2007 | 09:39 PM
Stamey's Avatar
OK, so anyone done this, and had the PM3 stop fueling?
I stacked my Drag Comp on my PM3 Comp and it works for a while, but then the Comp stops fueling. The Edge, from level 1-3, still seems to work, and if I switch the wire over to the Edge Comp, I can stop traffic with the cloud again. I just can't figure out why the PM3 stops fueling. When I give it fuel I see the boost and fuel light go on, on the remote, so it "thinks" it's fueling.
I can see no connection problems under the hood. I just put new bullet connectors on the wries under there because I DID find a connection problem a few weeks ago.
Any ideas?
Thanks,
Chris
Old Jul 23, 2007 | 10:13 PM
1-5-3-6-2-4's Avatar
Where did you get your bullet connectors? do you find them better/
I'm looking to install my PM3 here right away but don't have the 3 taps I need.
Old Jul 24, 2007 | 05:31 AM
Stamey's Avatar
Truthfully, I HATE bullet connectors, but I was repairing what was already there, and that's what I had handy. I much prefer blade connectors because they are easier to put together and pull apart (the important part) without pulling the wire out of the connector.
Chris
Old Jul 24, 2007 | 10:33 AM
OK and the blade connectors are called scotchlocks then?
Old Jul 24, 2007 | 01:35 PM
Stamey's Avatar
The connector you are thinking of is a variant of the "scotch lock" that comes with the PM3, if you don't get the "grabber" tap, that puts a female blade connector junction, tapped into the middle of the pump wire.
(I do not see the grabber on the TST web site anymore)
My problem with thos scotch lock-type connectors is they cut into the actual conductor material, severing part of it in many cases, and if the wire weren't subject to so much vibration, that might not be too terrible, but with the vibration and the possible corrosion....
Because it cuts the conductor a bit, I only use that type of connector as a last resort in any situation, and I stuff dielectric grease into it before I use it on a wire, just to try and keep the corrosion down.
This might be a better option: http://www.tstproducts.com/index.asp...ROD&ProdID=140
It may shield the cut in the wire insulation better than other taps. This may be the same as the Bluechip cover I have read about.
Chris
Old Jul 24, 2007 | 02:55 PM
RowJ's Avatar
Originally Posted by Stamey
.... I just can't figure out why the PM3 stops fueling. When I give it fuel I see the boost and fuel light go on, on the remote, so it "thinks" it's fueling..... Any ideas? Thanks,Chris
Check your In line fuse near the box. I think I remember mine doing just like yours (fueling light but no fuel).
It's a 5v fuse and can look OK when it's not... so just replace it.
I have used a 'Grabber' for 4 yrs and two VP-44's. I think TST told me they stopped selling cause price went up. Should be able to find them on the internet... know I use to see them elsewhere. I think they are great!
RJ
Old Jul 24, 2007 | 08:51 PM
Stamey's Avatar
Will check that tomorrow.
Thanks,
Chris
Old Jul 26, 2007 | 05:11 AM
Stamey's Avatar
Checked the fuse last night. It looks good. Anything else I should check?
Thanks,
Chris
Old Jul 26, 2007 | 10:22 AM
Ph4tty's Avatar
The ground. TST needs a real solid ground. Mines grounded to the frame.
Is the fueling light working on the box itself?
Old Jul 27, 2007 | 07:50 PM
Stamey's Avatar
Yes the fueling light is working. My ground is the same place it has always been, the tapped wire as per installation instructions. I will hook it up again tomorrow and see if it has decided to work. For the past few days I had the Comp wire connected to the pump.
Chris
Old Jul 27, 2007 | 10:02 PM
99globalwarmer's Avatar
hey guys kinda off subject but they have a new wire tap called a posi-lock super nice super sweet. heres a link
http://www.posi-lock.com/posiplug.html
