need expert advice
Old May 27, 2003 | 11:44 PM
peanut's Avatar
need expert advice
ok, i just bought a tst powermax2 for my 2000 dodge, i have heard one guy say it might be bad on the stock clutch, others say not. I have not installed it yet and kinda plan on gettin a pyrometer. is the boost and oil temp guages neccessary? Is the pyrometer even neccessary? Do i really need to worry bout my clutch?<br><br> i would really appreciate any comments u might have. <br> thanks.
Old May 27, 2003 | 11:47 PM
Got Smoke?'s Avatar
Re:need expert advice
[quote author=peanut link=board=7;threadid=15215;start=0#142882 date=1054097071]<br> ok, i just bought a tst powermax2 for my 2000 dodge, i have heard one guy say it might be bad on the stock clutch, others say not. I have not installed it yet and kinda plan on gettin a pyrometer. is the boost and oil temp guages neccessary? Is the pyrometer even neccessary? Do i really need to worry bout my clutch?<br><br> i would really appreciate any comments u might have. <br> thanks.<br>[/quote]<br><br>A PM2 is going to quickly test the limits of your stock clutch. How many miles are on your truck? Don't run it very hard and it should last you a while (i.e. till you can afford a SBC).<br><br>Would DEFINATELY get a EGT &amp; Boost guage.... don't wanna burn up your motor and ya don't wanna blow your turbo (just kidding you won't make that much boost)
Old May 28, 2003 | 10:20 PM
peanut's Avatar
my truck has 76 thousand miles<br><br>i appreciate the advice<br> thanks
Old May 28, 2003 | 11:44 PM
Got Smoke?'s Avatar
[quote author=peanut link=board=7;threadid=15215;start=0#143300 date=1054178417]<br>my truck has 76 thousand miles<br><br>i appreciate the advice<br> thanks<br>[/quote]<br><br>I bought my truck as the 3rd owner and I knew the guy I bought it from and he never replaced the clutch and he had it since it was a year old. At 153K I went to my TST clutch.... well over due for a clutch but as always $$ was tight and the stock one was still holding unless throughly punished.<br><br>Depending upon how hard you are on your clutch with that PM2 (and considering I don't know the #'s it makes) your clutch could last a good while......but if you rag it it will go quick. <br><br>Just the truth.
Old May 29, 2003 | 12:45 AM
KATOOM's Avatar
Check out some past posts about gauges. They are a MUST HAVE item, especialy if you want to add any mods!
Old May 29, 2003 | 01:50 AM
Rob Thomas's Avatar
I'll say this, at 35,000 miles I installed a PM 2, (my first mod) the clutch slipped on the test ride, ordered new clutch that day. Some people have had they're stock clutch last a good while, and some don't, just be prepared, and like said above, gauges are a must, fuel pressure, and EGT at least.<br><br>Later, Rob
Old May 29, 2003 | 02:11 AM
Idaho CTD's Avatar
I had a '99 5spd that I put a PM 2 on at 20k. The stock clutch lasted til 104k. Yes you definately need a pyro. In the summer it was easy to pass 1300* on any decent hill.
boomerang
May 5, 2014 04:44 PM
madhat
32
Jul 11, 2011 08:09 PM
penguinman
Mar 27, 2010 03:57 PM
Stamey
May 18, 2006 11:36 AM
DF5152
May 12, 2003 12:53 PM
