is this my turbo
Old Mar 4, 2005 | 05:21 PM
luke h's Avatar
is this my turbo
well when my stock wh1c bit the dust i installed a rebuilt hx35 instead, before the 35 there was a very noticable whine under acceleration, sounds like a power drill, now i know my turbo is supposed to whine but it wasnt as loud when i put the 35 in, now its as loud or louder than before, almost sounds like a ps pump or something, the only thing is when i let off throttle i can here variations in the pitch like the wastegates opening, it does at 10 psi of boost, but at 36-40psi its screaming, scares me to take it that high since ive had bad luck with turbos and them screaming back at me
Old Mar 4, 2005 | 06:23 PM
cumminsdriver635's Avatar
Hey Luke! Mine screams like a banshee at about 35lbs of boost Did it just starty sounding like this or what? You still liking the Delivery Valves? What is the hottest your EGT's get to?
Eric
Old Mar 4, 2005 | 06:55 PM
luke h's Avatar
delivery valves
its probably a noise thats been there since weve had the truck but sometimes my ears will pick out a weird noise and focus on it, its weird, about the delivery valves, there awesome, at 70 mph egts are right at 650 but my probes after the turbo, i can get them hot by holding my foot into for a while but its not nothing were i have to drive by them, what egts are you seeing
Old Mar 4, 2005 | 09:01 PM
hotmopr's Avatar
650 post turbo is pretty darn hot for 70 mph cruising. I see 650 pre turbo cruising at 70.
Old Mar 4, 2005 | 11:04 PM
My EGT's are about 1450 by 60mph if i bury the pedal. I can give it almost, but not quite all its got, and keep them around 1200. Mine is pre-turbo. That does sound hot if your probe is after the turbo. Could be right if you were on a small grade with a hard headwind or something though. Maybe your turbo isnt spinning freely? Take the intake off, and feel the shaft for play. If you cant make the impeller hit the housing by moving it around, then its fine. I think in and out play is pretty bad though. I might have to go for some delivery valves when i get my tranny upgraded
Eric
Old Mar 7, 2005 | 01:56 PM
luke h's Avatar
i lied
i was making a guess when i posted that, i checked them last night. results: 60 mph 450, 70 500 and at 100 mph 750-800
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
