My Custom Gauge Mount
Old Apr 27, 2006 | 08:09 PM
craneage2001's Avatar
The previous owner of my truck only installed the EGT and pyro gauges on the a-pillar, so I knew I needed a fuel pressure gauge. He used the Autometer Ultra-lites...while I liked them, I didn't want to mess with the existing setup and I really didn't want to spend $200 on the matching FP gauge. I thought about the steering column pod, but didn't care for its placement of the gauge, so I decided to fab up a pod on the ash tray...NOBODY is going to smoke in my truck anyway!
Here it is...I'm quite happy with the result:
And of course, my lovely assistant:
Old Apr 27, 2006 | 08:12 PM
Crimedog's Avatar
Nice work! Looks factory
Old Apr 27, 2006 | 08:13 PM
dodgediesel's Avatar
Thumbs up
Excellent job!!! Looks like it was out of a autometer warehouse..
Old Apr 27, 2006 | 08:18 PM
98silver12v's Avatar
Smile
Hey nice work! Looks great! very clean install!
Old Apr 27, 2006 | 08:25 PM
ds1rider's Avatar
Loogs great. Man, your dog's tail is kickin'
Old Jun 10, 2006 | 03:42 AM
coyote204's Avatar
I Like It!!
Looks great. Can I ask how you did that?
Old Jun 10, 2006 | 05:20 AM
Andy505's Avatar
Very nice!! I've got my fuel pressure guage in the ashtray as well...but its just sitting in there...but I like your setup...I am inspired now!!
Old Jun 10, 2006 | 05:30 AM
Mountaineer's Avatar
nice
Good job, I would say you could could have people send their ash trays to ya to get a mount installed and have a sweet little business going on
Old Jun 10, 2006 | 08:40 AM
displacedtexan's Avatar
You really did a good job on that man!
Old Jun 10, 2006 | 11:21 AM
I do my share of fabrication, but not by trade...I'm mainly just a tinkerer with patience.
The ash tray does still open...it was possible (with a bit of fiddling) to run the lines between the gray outer cover and the black plastic bin, but since I don't use my tray for anything, I just ran them through the inside. There's some pretty big holes to run through the dash once you're in the tray; if you pull out your ashtray, you see what I mean.
It went together pretty fast, but that's only because I actually had a pod to work with. I simply cut the backing off the pod I had and shaped it to the curve of the tray; a tiny bit of glasswork to hold it on/taper it to match and it was good to go.
If you've got a pod handy or just find one cheap, its a really easy hour-long project. Most pods are cheap plastic and really easy to shape! :-) I'd have no problem doing another, given an ash tray and a pod, but anyone with a small saw and a file can do it.
Old Jun 10, 2006 | 01:17 PM
rebal's Avatar
DIDO! LOOKS GREAT!
Old Jun 10, 2006 | 02:16 PM
gwhammy's Avatar
That is a heck of a job, it looks factory! Please tell me you didn't run raw fuel pressure into the cab with you?
Old Jun 10, 2006 | 02:18 PM
Tom's Avatar
Tom
craneage2001,
That really looks good. I like it. Like the assistant !!
Tom
Old Jun 10, 2006 | 03:47 PM
BC847's Avatar
1st Generation Admin
Aw jeez. . . .
There's a lot of folks here who've done it and haven't burned yet. Therefore it Must be safe. (No flaming intended).
Hopefully, he's got some sort of isolator in-line outside the cab.
That'd be the frosting on an outstanding job.
. . . . .. He did say nobody would be smoking.
Old Jun 10, 2006 | 04:49 PM
RATTLINRAM's Avatar
That does look good! I put mine in the dash where the cubby hole used to be.
I'll have to take a pic of my ashtray with Howard's Turbo Cooldown Timer and my TC lock-up switch in it. (BTW,,,,,, I still smoke, but I have always used a small hole ashtray that sits in the cupholder.)
