mpg with #100 and #0 fuel plates
Old Aug 27, 2007 | 03:59 AM
drolex's Avatar
I haven't seen the mpg that people get with these fuel plates. I am just wondering what kind of mileage you can get with a 0 or 100 plate. Maybe list the best mpg you can personally get with one and the usual mpg.
Old Aug 27, 2007 | 05:40 AM
rhino 660's Avatar
i have a 100 best was 17.4mpg normal is 15 to 16 and i am not easy on that skinny pedal awalys smokin people out
Old Aug 27, 2007 | 07:33 AM
schoust's Avatar
Yea I believe it's all in the driving style,then again if you have one of those plates you are more than likley not worried about milage...........
Old Aug 27, 2007 | 08:58 AM
Muddin_dude06's Avatar
As long as you have your AFC enabled changing plate profiles will not make a difference on your mileage if you drive easy. I get just as good of mileage with a DEEP #100 plate as when the stock plate was in the truck slid full-rear, as long as you don't mash the go-pedal it won't make a difference.
Old Aug 27, 2007 | 10:48 AM
jlipskoc's Avatar
I have a 0 and can get 23-24 mpg, thats on those single lane highways with speed limit of 60mph. I get on the interestate 70mph, get about 20mpg.
I agree, its all about your driving style, how deep you press the go pedal, and how fast your going. Anything over 60mph, the wind i think is your main factor.
Old Aug 27, 2007 | 03:06 PM
dalee's Avatar
dido your foot makes all the diference me 16-18
Old Aug 27, 2007 | 06:33 PM
TxDiesel007's Avatar
100 plate
16-17 in city, and 21-22 highway, with 16.5 degrees, dragon fly injectors, and my plate full forward.. AFC is at centered position tho... smoke with 181's is controlable and mileage went up 1-2 mpg over laser cuts...
Rick
Old Aug 27, 2007 | 07:07 PM
drolex's Avatar
Yes, I know your foot makes all the difference. That's why I asked for your best and usual mpg numbers. Your modifications do have an effect, and that's why I'm asking.
I just calculated my mpg over 96.8 miles on my B100. Sadly it was 16.16 mpg. I found the density of my own B100 and then filled the tank back up and recorded the change in mass of fuel that went in and then divided by the density. So, my measurement of fuel that went in was pretty accurate but maybe the tank accepted more fuel this time or something. I drove lightly with lots of non-stop at good speeds (good for mpg). I never did calculate the mpg with my modifications and diesel #2, though. I know I should use greater distances for calculating mpg.
Old Aug 27, 2007 | 08:45 PM
Willy91's Avatar
I got 17.5 this last tank with a 0 and a gutted AFC housing, done up just especially for the diesel extravaganza.
Old Aug 28, 2007 | 12:48 AM
drolex's Avatar
You mean, made to smoke? That tank must have been used on almost all highway or mostly constant speeds.
Old Aug 28, 2007 | 11:10 AM
Box5's Avatar
I get the same milage as before without the 100 plate. I average 18.6-19mpg, can get 20-21 if i'm really easy on it, but who can be when u need to get that turbo spooling every time u leave from a stop, lol. I have stock injectors, I think injectors are the thing that will start to hurt mpg alittle, cant say for sure but i'll probably find out soon, lol.
Old Aug 28, 2007 | 12:23 PM
William12Valve's Avatar
I am runnin 21 to 22 on the highway but when i get into the big city it gets pulled down to 16 to 18. I wouldnt have any idea why that is With two jeeps on the gooseneck (grossed at 20700lbs) goin over the pass i ran about 12 mpg.
Old Aug 28, 2007 | 01:16 PM
Sunir's Avatar
What are fuel plates and what do they do? Are the only choices 0 or 100, and what do these numbers mean? Is is a mod for more mpg's...I'd like to get more mpgs, relaible mild power if any (I'm not hard on the pedal much at all) and effeciency for my '01 CTD daily driver...
Old Aug 28, 2007 | 01:49 PM
Lil Dog's Avatar
With an 01, you are 24 and electronic so plates don't apply..Mechanical pump part..
As far as mileage dropping with Bio, depending on the type of oil, soy or canola, the BTU or heat energy in the fuel will be slightly lower than the pumped petroleum product. Therefore you need more fuel to do the same job. But if you are brewing it yourself, the cost savings is worth the slight drop in MPG. I noticed mine went down slightly with Canola based Bio. Smelled like french fries, but who cares? I got it for 1/2 price of pumped fuel..
Old Aug 28, 2007 | 08:25 PM
johnsjas's Avatar
As long as its not a week that I go to the track, I see around 19mpg (give or take) but I drive like an old woman on the street.
