most hp made out of a 40 turbo
Old Jan 2, 2005 | 03:32 PM
king d's Avatar
just wondering whats the most hp seen by using an hx 40 turbo,with and with out nos...thanks..jess
Old Jan 2, 2005 | 03:52 PM
Timinva's Avatar
DTR Advertiser
Jess I have seen guys go 500hp with a pdr40 on a dynojet it gets hot though. I would be real careful with a 40 and n2o though. Hx40 shafts are not real strong. I did run a pdr40 a lot, at about 40 lbs of boost with no problems. Stock 40s probably would not take this though. Tim
Old Jan 2, 2005 | 03:55 PM
Forrest Nearing's Avatar
I've been running a stock 40 at 40-42psi for 25k miles
Forrest
Old Jan 2, 2005 | 04:39 PM
Don M's Avatar
DTR Advertiser
I have seen 531 with a set if Mach 5's Pretty crispy though.
Don~
Old Jan 2, 2005 | 04:42 PM
Kyle Graham's Avatar
What were the boost pressures at 531hp do you remember
Old Jan 2, 2005 | 04:43 PM
oh yeah, I had the shaft and compressor wheel balanced by Majestic, so it's not 100% stock.
Forrest
Old Jan 2, 2005 | 04:44 PM
John_P's Avatar
Jess:
On my 1996 Dodge CTD I ran 508 H.P. with the Piers HX-40/16. With my 2002
my best dyno run has been 486 H.P. with that same turbo, the TST PM 3 and
high flow (125 HP) injectors. Neither truck really had what I would consider
"high EGT's", as both of them hit about 1400-1450 degrees on the runs. Tim
is right about the boost though. The "stock" HX-40's can't take a steady diet
of boost into the high 40's, low 50's. On both my trucks I had the wastegates
set to about 38-40lbs. and they seem to make good power there and have
excellent durability. Another thing I like about the HX-40/16's is the low-end
response. The lag is very minimal on my automatic and takes off very, very
well. As you saw last year at our dyno day, we were able to see a 12.94
E.T. at the drag strip with cool air.
John_P
Old Jan 2, 2005 | 05:21 PM
PourinDiesel's Avatar
501hp 1080ft lbs with a PDR40, 125hp injectors.
Old Jan 2, 2005 | 05:35 PM
Deezle1's Avatar
I've been thinkin about a hx40. or twins...or an HX40 in the twins kit I sorta beat the poo out of the ole hx35 with all the fuel...
Old Jan 2, 2005 | 07:23 PM
clc900's Avatar
whats the diffrence between a 40 as a single and a 40 used in a twins package?? I am thinking about doing a 40 and then later on using it as the top turbo for twins. Would I have to make any modifications to the 40 in order to do this??
Old Jan 2, 2005 | 09:03 PM
nope. it'll spool a little slower in the twin config... you could have an Hx35 turbine housing machined to take the HX40 turbine wheel. that's what I'm going to do when my twins go in.
Forrest
Old Jan 3, 2005 | 02:09 PM
John_P's Avatar
clc900:
One thing I had done to my HX-40/16 when I went from the single set-up to
using it on top (at the manifold) in my Scheid Twin Turbo Set-up was to have
the HX-40/16 exhaust housing wastegate "flapper" hole enlarged some.
This helps the HX-40 "bleed off" more exhaust gases than it originally did
and it helps the drive pressure.
John_P
Old Jan 3, 2005 | 02:49 PM
clc900's Avatar
Cool, Thanks!
Old Jan 10, 2005 | 08:24 AM
1st gen Hobie's Avatar
Will the hx-40 bolt up to a 1st gen manifild w/o problems?
Old Jan 10, 2005 | 10:13 AM
yup!
