most efficient injectors for mpg
Old Jan 28, 2008 | 04:54 PM
Tate's Avatar
The throttle linkage in the pump is all on a set of springs. The difference the rack sees in the pump (controls the amount of fuel delivered) from half throttle to full throttle may not change, depending upon plat design and position. You could get great mileage with no plate or AFC, or terrible mileage if you have both of them full back. Depends on how your drive. You will get the same mileage at the same speed regardless of which plate you run, because it still takes the same amount of fuel to keep that speed up. Its when accelerating where difference becomes apparent.
Old Feb 10, 2010 | 09:48 AM
lgp9999's Avatar
Originally Posted by greenrig
i know there is never one answer to better mpg's but what is a more fuel efficient plate?
A fuel plate will not change your cruising MPG, it only dictates how far the throttle can go at its maximum point, as I understand it. Someone correct me if I'm wrong.
As for the turbo, post a pic of it.
Old Feb 10, 2010 | 12:25 PM
scottsjeeprolet's Avatar
Swamp_Donkey
ABDTR #5
23
Oct 10, 2009 03:34 PM
Tree DR
Apr 2, 2007 08:01 PM
nitis
14
May 5, 2006 01:20 PM
Luckycharm1
38
Sep 12, 2005 10:54 AM
bausman
14
Aug 3, 2005 01:10 AM
