More HP
More HP
With my sig in mind,(stock turbo/100hp inj) What would be the answer to gaining some more horsepower somewhere between 450-500 for the end result? Turbo and bigger injectors no doubt but what would be my best options? Everyday driver! Kinda hoping for a little quicker spool up if thats achievable.Thanks for your time.
If it were my rig I'd probably stick with the injectors you've got if you've already dyno'd 360 rwhp. Remember that with the HO pump you'll usually gets more than advertised HP on injectors. Turbo I'd probably go with a 62/71/14 unless you tow often than I'd go 62/65/14. Put a TST PM3 other there and call it good. With my VP's this was one of my favorite setups, though I'd run 125 or 150 hp injectors. you can run around with just the smarty and injectors. It's keeps smoke down and you're still able to tow good. If there's someone on want to play with flip the TST on (mine was always set to 9) and have some fun. With adding just the turbo and TST it should easily put you into your power goal. As for turbo, if you're looking to save a little money look up forced inductions. It doesn't have the fancy HTT or II name but will do the job just as good.
Well, interesting you mention the tst power max 3 because I still have one in my truck! lol I just didn't hook it back up after istalling the HO pump for fear of voiding my warrenty but that has been a couple yrs ago. What setting did you run your smarty on?
Over the years I've run almost all the borg warner/garrett holset turbos going, hard to beat the stocker for spool-up. A few mods to the turbine housing and/or use of an external wastegate would be the hot ticket. You can build twins for your truck cheaper than most S300 T-3.
Lots of issues with the S300, small bearings/smaller shaft.I recommend run an edge comp box, I put down 673rwhp in my truck a few years back. I just haven't had a chance to put my second turbo back on.
JyRO
Jan 20, 2006 09:28 AM
Commatoze
Nov 20, 2003 06:06 PM
