Modding the hx35
Old May 21, 2006 | 04:12 PM
jaymo's Avatar
Modding the hx35
So now that ive got the clutch Its time for new Pipes, The straight piped 3.5 is'nt going to cut it. So my question is, upgrading to a 40 housing worth the trouble? That way I dont have to buy a differant down pipe when I decide to get a differant turbo. Or I guess will my 35 with a 40 housing worth any thing at all? I just dont want to buy two downpipes... I am a little confused about all this turbo stuff. Mabee what I mean is a 14 cm housing not a 40. but does this still mean I have to change down pipes?
Thanks....Jay...
Old May 21, 2006 | 11:42 PM
bmoeller's Avatar
The hybrid 40/35 turbos have a compressor wheel/housing from a HX40. The turbine housing/wheel is from a HX35 turbo. Assuming you have HX35, the downpipe will be the same for the hybrid. Several other turbos use the same size/style of flage on the turbo. The 14, is the size of the turbine housing. 14cm2.
I have a HX-40, and they take a different downpipe.
Old May 22, 2006 | 06:26 AM
jaymo's Avatar
Yea I am so new to turbos.
I guess I should have asked what turbo am I going to have to get without buying things twice.I know this is a very broad question but I spent 2 hours reading turbo info on the search. And now I am more confused....
In my sig is what I have, I will be adding at least 100 hp injectors and then an exhast. Or maybe the other way around.
So far I have done as everyone has said and bought what I realy want so I wont do it twice.
I am a carpenter and I use my rig for work. So I have about 500 lbs in the bed all the time, But also trailer my jeeps to the trails. Probably 8500 lbs at most.
I just want to try and find a good balance in performance the first time. And so you guy's havent steered me wrong so far.
Thanks for the help.....Jay....
ROADWARRIOR
Dec 27, 2014 12:02 PM
Artsi_L
Dec 26, 2005 03:52 PM
Austin K
Apr 21, 2005 06:01 PM
Barrett_Fodder
Oct 7, 2004 12:12 PM
gasgas19
Jun 13, 2003 12:15 PM
