Mech Fuel Gauge Question
Old Oct 4, 2002 | 10:46 PM
SmokinShaker's Avatar
I'm sure this sounds dumb but, I'm finally getting around to hooking up my fuel pressure gauge and I'm not sure exactly where to hook it up. I have the steel braided hose with fittings but what do I hook up to on the engine?
Thanks,
Ryan
Old Oct 5, 2002 | 12:48 AM
CMN_NOT_STROKN's Avatar
Re:Mech Fuel Gauge Question
I haven't done this but I have heard that you want to tap between the fuel filter and the injection pump. I am not exactly sure where. If you do a search you should be able to find your answer. Also check out www.dodgeram.org and click on diesel engine. They have lots of info on there. Good luck.
Old Oct 5, 2002 | 08:39 AM
Thanks fellas
Old Oct 5, 2002 | 10:53 AM
PaulG's Avatar
Since you have a '99, you can attach the hose to the top of the fuel filter housing. On the '98 and '99 models, there are two ports on top of the filter housing: one is for pre-filter pressure and one is for post-filter pressure. In '00 they changed the filter design, so the newer trucks don't have the test ports.
Old Oct 5, 2002 | 11:56 AM
[quote author=Paul Guthrie link=board=7;threadid=5581;start=0#48951 date=1033833187]<br>Since you have a '99, you can attach the hose to the top of the fuel filter housing. On the '98 and '99 models, there are two ports on top of the filter housing: one is for pre-filter pressure and one is for post-filter pressure. In '00 they changed the filter design, so the newer trucks don't have the test ports.<br>[/quote]<br><br>THANK YOU! I'm on my way out the door to do it now ;D
Old Oct 5, 2002 | 01:56 PM
Well it's on, no leaks. Thanks guys ;D
stock600
51
Apr 11, 2008 06:34 AM
dctoner
Jul 27, 2005 10:17 PM
xp8103
May 2, 2005 07:14 AM
taken5875
Nov 4, 2004 12:56 PM
taken5875
Oct 4, 2004 12:38 AM
