Max Flow Kit
Old Jan 25, 2005 | 06:54 PM
wrangler's Avatar
Max Flow Kit
Who sells a max flow fuel kit now that Wildcat is closed, sad to see them close Rod was great to talk to when I bought the EDM injectors. If I cannot buy the kit can someone provide the specs as to what is in the kit. I am sure Summit has all of the fittings. Any info would be appreciated
Wrangler
Old Jan 25, 2005 | 07:02 PM
tankeryanker's Avatar
Scotty is selling a simular kit if I'm not mistakin.
Old Jan 25, 2005 | 07:04 PM
Dr. Evil's Avatar
Yes he is......www.scottyairsystems.com
Old Jan 25, 2005 | 07:34 PM
seabee's Avatar
yes he does its a nice kit i have it on my truck . that white dodge you see in the instructions is my truck. i really like the kit these 1/2 lines are awsome.
Old Jan 25, 2005 | 07:38 PM
wrangler's Avatar
Great!! at 199.99 I probably couldnt buy the pieces from summit and this is all ready to go as I cant afford downtime. Has anyone installed this kit and can aynone report an there fuel pressure before and after
Wrangler
Old Jan 25, 2005 | 07:42 PM
seabee's Avatar
i have installed it the kits easy to do . if you read the instructions at the bottum theres were i reported my pressure reading before and after. if i remember right i was around 14 psi at ilde and like 10 at wot and now with a new lift pump im at 16.5 to 17 at ilde and can suck it down to 14at wot up a good grade even with my van aakens box.
Old Jan 25, 2005 | 08:03 PM
seabee's Avatar
the install will be a little different than mine on your truck cause of the different filter housings. but it should be really easy . I have had to change out a lift pump since the lines were put on and that was just as easy as it was with stock lines on here.
Old Jan 25, 2005 | 08:11 PM
Scotty's Avatar
Top's Younger Twin
Thanks for the good reports.
I also include a tube of Teflon thread paste to assist with a leak free assembly.
These kits sure go fast. Thanks to everyone for their support. The original Max flow was my design, I had this idea on the shelf for awhile and once wildcat took a dump, I brought it out so as not to compete against something I already designed.
PM me if you are interested.
I think I am within the site guidelines. Either that or I am gonna get a scolding.
Scotty
Old Jan 25, 2005 | 08:17 PM
seabee's Avatar
your welcome scotty,
thanks for the good lines. By the way i didnt notice any drop in pressures when i put my van aakens box on here. that lift pump we did the original testing with was on its last leg . so these new numbers are probbly a little more reliable. just to let you know.
Old Jan 25, 2005 | 08:27 PM
Scotty's Avatar
Top's Younger Twin
Its always good to have a fresh pump so you have a good baseline. Glad it worked out for you. Keep the old one as a spare in case Murphy shows up.
Wrangler, I replied to your PM.
Scotty
Old Jan 25, 2005 | 08:38 PM
seabee's Avatar
when this one gives up im going to put the fass 2 set up on here so i can keep the filter housing and these lines along with having the fuel heater.
Old Jan 25, 2005 | 08:39 PM
phox_mulder's Avatar
Scotty
I think you are, besides, I'm not gonna volunteer to scold you, I like my bones nice and straight.
phox
Old Jan 25, 2005 | 09:52 PM
wrangler's Avatar
thanks for the quick reply scotty as soon as I get it I will post before and after numbers
wrangler
Old Jan 25, 2005 | 11:22 PM
Dr. Evil's Avatar
Scotty,
Heres a question - how does the max flow work with a fass?? Is it worth doing?
Old Jan 26, 2005 | 12:08 AM
Scotty's Avatar
Top's Younger Twin
Not sure but some folks have purchased for this application.
Scotty
