Map sensor reading
Old May 25, 2009 | 12:29 AM
Bradleysram's Avatar
Map sensor reading
how much psi will the factory map sensor read.
Old May 26, 2009 | 09:15 PM
gotslicks's Avatar
why do you ask?
Old May 27, 2009 | 04:23 PM
because i would like to either use the pulse or juice as my boost guage and was wondering if it would be accurate being as the twins im getting well be between 50 and 60 psi
Old May 27, 2009 | 06:02 PM
Fishin2Deep4U's Avatar
The sensor will work up to 58 or so psi. However, the ECM does not use that much of the range. I believe it's clipped at around 48psi. I would have to confirm this. The Juice will also be limited to the same value IIFC.
Dave
Old May 27, 2009 | 06:25 PM
im just wanting to avoid another guage. As cool as more guages are i would like to use the built in guages in the module
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
