MAP Sensor
all i know is that if you have an Edge comp/drag box and you unhook the map sensor it smokes alot more.. i do it on mine sometimes and with the bd injectors i have it smokes up a storm.. but lots of people get mad if you do that (those behind you) lol..
Without a box it will throw a code, and maybe throw the engine into limp mode.
If he wants smoke he needs gauges and a fueling mod, Comp, Smarty, injectors... Build for power, and the smoke will come.
is it bad to leave it unpluged for long periods of time?? I have a buddy that says it could melt down the pistons!!! true?
EDGE COMP,BHAF,MBRP EXAUST,40 HORSE INJECTORS,PYRO,BOOST,AND FUEL PRESSURE GAUGES.
THANKS.
THANKS.
Unplugged the one on my 01' and I have a juice w/ att. and it throwed a code and limp mode???? I unplugged it from the block and the connector to the wiring harness is that rite or did i do something wrong???
Jake
Jake
Just unplug the whole harness from the block. Leave the factory wiring harness plugged into the comp harness. I would tie it up to the firewall so it doesn't hang down and get dirty. But make sure your comp is always turned on when it is unplugged, or it could possibly throw a code and put it in limp mode.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
Booost Almighty
Jan 1, 2006 01:41 PM
