Maintenance Questions
Old Aug 23, 2005 | 05:57 PM
Timberman's Avatar
My truck is approaching 85,000 miles, and is 6 years old. And very stock. What kinds of maintenance issues should I be considering soon? Should you replace the water pump, or the fuel pump, (what is a lift pump?) or have the valves checked, etc. at this point? Figured I'd get some routine stuff done to keep her in good shape.
Old Aug 23, 2005 | 06:51 PM
CTD_Neil's Avatar
Do you have an owners manual? Mine has the maintenance schedule for given mileages. Makes it easy to keep track of what has/needs to be done and when.
Old Aug 23, 2005 | 07:04 PM
P.J's Avatar
P.J
Fuel system is comprised of two pumps. A Lift pump is kinda like your standard fuel pump, but rather than being inside the tank it's located in the engine compartment. The Injection Pump (VP44) is the pump that actually creates the high pressure flow to the injectors.
LP= $130.00
VP$$= $1,200-1,600
The object is to not let the Lift Pump fail and reduce or cut off the supply to the Injection Pump, this could lead to Injection Pump failure and a costy repair.
Old Aug 23, 2005 | 08:10 PM
Timberman's Avatar
Yeah, I see the suggested maintenance schedule in the owners manual. Dang, I'm behind. I've got to back up to the 60,000 mile list. Fan hub, damper, water pump weep hole (!), coolant, belts. Can I find info on how to inspect and replace these parts in like a Haynes or Chilton manual? I've got some inspecting to do, evidently. Just wondering if there were any parts that were notorious for failing and costing lots of $ to fix, that can be replaced easily ahead of time.
Thanks for the info on the lift pump. Is it a good idea to replace it, does it wear out eventually, and cause injector pump failure?
Old Aug 23, 2005 | 08:41 PM
phox_mulder's Avatar
Yes.
If you're still on the original lift pump in a 99, you need to go buy a lottery ticket ASAP.
Forget the Chilton's, and get the real service manuals.
http://www.techauthority.com is a good place to get them.
phox
Old Aug 23, 2005 | 08:58 PM
Timberman's Avatar
10-4 on the lift pump, I'll get that replaced ASAP. Thanks a lot for the link. I'll order a service manual for it, I'm sure it will come in handy. $90, ouch!
Mark Hodowanec
Sep 7, 2004 10:39 AM
Jmac
Aug 19, 2004 09:21 AM
tanderson2002us
Jun 17, 2004 07:41 PM
MD Mudder
Nov 25, 2003 03:50 PM
DomVic
Aug 27, 2003 01:40 PM
