Mag Hy Tec Question
Old Oct 10, 2005 | 07:36 PM
BigBlue's Avatar
Mag Hy Tec Question
I got my double deep pan in today and it's nice and perdy. But I've got a question. It gave me a filter drop bracket thingamajigar. When Chris at relentless installed my new vb, he also put the old 94 style filter on it. I think it uses 3 bolts instead of two (or maybe the other way around). My question is should I install the drop bracket or not? I'm figuring yes but the instructions have to many words for this simple boy to comprehend. Also, I bought an extra 8 qts of fluid for this thing. I'm gonna try and save as much fluid as I can out of the tranny because it's about 1 1/2 weeks old. How much fluid should I need? Thanks yall.
Old Oct 10, 2005 | 09:49 PM
jfpointer's Avatar
The '02 FSM says a service fill for either auto is 4 quarts. Should be the same for your '01, I'd think. So unless the Mag-Hytec pan more than doubles the capacity you should be fine. I dunno about the bracket thingamajig.
Old Oct 10, 2005 | 09:57 PM
BigBlue's Avatar
Actually, if you drain the torque converter also, it takes 12 quarts. I know the double deep adds somewhere around 4-5 quarts but I want to be sure before I tear into this thing.
Old Oct 10, 2005 | 10:14 PM
jfpointer's Avatar
I think "service fill" probably means just dropping the pan and changing the filter. FSM lists 19-20 pints for the 46RE and 29-33 pints for the 47RE as the overhaul fill.
Old Oct 10, 2005 | 11:41 PM
BigBlue's Avatar
Ya. I figured as much. Cheap way to do it. Not the right way, but the cheap way.
Old Oct 11, 2005 | 03:47 AM
Holsteinman's Avatar
Yes install the spacer. It lowers the fluid pickup point near the bottom of the pan. The pan holds 9qt by its self. When you drop a pan some fluid comes out of the V/B so you will need between 9-11qt just for a pan drop.
Old Oct 11, 2005 | 07:17 AM
BigBlue's Avatar
Aight. Thanks for the help yall.
Old Oct 11, 2005 | 07:57 AM
whitebuffalo's Avatar
i had one on my 99 and it held a full extra gallon over the regular pan. also, IIRC, the filter pickup spacer only used two bolts, the third you just left in place. this was on a 46RE, I dunno how different the 47 would be....
billmac
Sep 22, 2007 07:44 PM
Luvnacumns
25
Apr 8, 2007 03:46 AM
BigBlue
Sep 30, 2005 08:27 AM
herb
Feb 29, 2004 06:04 PM
ridofpwrstroke
Oct 28, 2002 12:15 PM
