Mad Eth
Old Sep 18, 2005 | 05:36 AM
Ph4tty's Avatar
Mad Eth
I read a post from six months ago where Don was talking about ETH injectors built to complement the MAD ECM. Any news or do we have any beta testers in the crowd?
Also any thoughts about using a comp (w/ appropriately programed ecm) or custom programmed tst to defuel the mad for slippery road conditions?
Old Sep 18, 2005 | 01:31 PM
HOHN's Avatar
I dunno if they were built for the ECM, but the Mach 3.8s are optimized for the ETH, IIRC.
I'd skip the Comp and go ECM/TST.
The ECM can't be changed on the fly. It's a mod that you are married to once installed. The only workaround in slick roads is driver skill and discipline. Turning off the TST won't help much.
Personally, I think the TST should be custom programmed to not add any fuel until after 20psi or so when paired with the ECM. The ECM is already giving max fuel from the VP44, so adding more at low boost just kills performance.
I'd certainly like to test the above combo-- a catcher with a custom TST box. The TST is going to be easier to customize than the ECM, that's for sure.
My thinking is TST for top end, ECM for bottom end, and try to hand off somewhat smoothly.
Am I crazy?
Old Sep 18, 2005 | 02:55 PM
Ph4tty's Avatar
I've been doing some reading and between comments that not all the power levels on the TST will be benificial and comments that TST can be programmed to *defuel* like the ez/comp leads me to beleive I can get the best of both worlds- catcher and in cab adjustability. Just a thought.
Old Sep 18, 2005 | 03:51 PM
Bart Timothy's Avatar
The TST has no way of defueling. It adds to what fueling is already there.
Old Sep 20, 2005 | 09:50 PM
trailrydr9's Avatar
Aside from money, and valve upgrades, would a Catcher, and a Redline box make a good combo? I heard that the Redline won't even kick in till after 2500 RPM's?
Old Sep 21, 2005 | 08:51 AM
Jetpilot's Avatar
Don't believe all you hear..... The redline fuels very hard down low! The RD on my truck fuels more than a custom Drag Comp did.
Doug
lyvwire
Mar 29, 2003 08:06 AM
Diesel Freak
Mar 27, 2003 11:30 AM
FireNhole
Feb 15, 2003 09:40 PM
nevrenufhp
14
Nov 27, 2002 09:55 PM
