Mach 4 question
Mach 4 question
Has anyone run these on a stock turbo without a box or smarty? What was it like. Would a smarty and these sticks be too much until a turbo $$$$?
Thx,
Eric
FYI - Street only, rarely tow more than 8k, but do see 8000+ elevation a few times in the winer.
Thx,
Eric
I wouldn't go any bigger than 100hp if you tow anything. I've seen a few guys run M4's with stock chargers & gotta watch the gauge just daily driving. At your elevation, I would look into some M1.6's or similar.
All honesty Bob, It does it on the street. I will get some footage as soon as I get this thing figured out. I think my problem was a bad ground, its running much better now. If no codes come in the next day or 2, I am gonna try to get footage before I take it to ADT for upgraded clutch on Monday. The wife always takes my camera, I swear my son is gonna be a movie star.
I see that when it's 10 degrees outside. ANd you have a hybrid correct?Towing, unless the R's are over 2k, crabby likes the 1300....
Dang you Bob.....
i ran M4's on a hy-35 with smarty and only saw 1200*IIRC.
my 100hp jammers were hotter and dirtier than the M4's.
But you really need another charger to get all the hp from the 4's.
also im at sea level and live in 90% humidity all the time
No problems DDing the M4s here. They can surely get toasty in thin air, but even stock truck will have high EGTs at 8K elevation.
If you're towing 10K in thin air with a stock charger, the M4s are borderline-- you could use them but you would most likely be always struggling with EGT. I'd go down to a M2 if you need to tow in high elevation.
JMO
JMO
i have 100 hp sticks in mine with my adrenaline, i had to hurry to my house the other day because my alarm was going off and i seen 1600 really easy still had throttle left to
but without a box it might be ok.
Who's towing what with the mach 4s and a stock turbo? Thats who I would like some more details from. I wanna get some 4s, but I will have to use the stocker for a while before I can upgrade. Trying to figure if I can make it work.
Thanks
Josh
Thanks
Josh
I don't want to have to buy them twice.
