lp warning lite
Old May 27, 2006 | 06:22 AM
dugout's Avatar
lp warning lite
Just had a dash mounted warning lite installed in my 2001.5 for lift pump low pressure.
Anyone using this method,lite comes on if pressure drops, My question is at what number does the lite come on,I did not get any printed info,also are they(warning lite) any good.
thanks for the come back
DOUG
Old May 27, 2006 | 08:53 AM
Morology's Avatar
Not sure which setup you have but the one in my truck lights up when the fuel pressure gets below 4psi. Really inexpensive and can save you from running without the proper fuel pressure. Mine started flashing last week. Then came on solid. Checked for fuel pressure and had none out of a 3 month old lift pump. Glad i had the light.
Old May 27, 2006 | 09:23 AM
Geico266's Avatar
A fuel pressure guage would have told you a month ago it was going out, a light tells you when to shut the engine off.
There is a reason they call them "idiot lights".
Old May 27, 2006 | 11:29 AM
piperca's Avatar
I think the light is a good feature, since you're not always looking at the gauge. In my case, the pressure runs between 12 and 13 all the time, but occasionally drops well below 4 psi. If you're not watching for it, you don't know it's doing it. A light would instantly alert you of the problem.
Geico266 is right, you should invest in a gauge so the pressure can be monitored.
Old May 27, 2006 | 02:40 PM
99smokindodge's Avatar
Do you guys reccomend a mechanical or electronic fuel pressure gauge??
Old May 27, 2006 | 03:05 PM
P.J's Avatar
P.J
Mechanical. Cheap, fool proof, easy to install, does the trick.
Do a search on the topic, I would say most people are running fuel straight to the gauge witha needle valve inline.
Boss
49
Nov 23, 2005 04:38 PM
BSciosciaJr
May 29, 2005 08:56 PM
bentwings
May 21, 2004 09:21 AM
SjLingenfelter
Oct 7, 2003 01:28 PM
fourknee
May 21, 2003 10:04 AM
