LP upgrade
Old Apr 30, 2007 | 02:08 PM
duramjames's Avatar
LP upgrade
I need to upgrade my LP.Where can I buy LP upgrade,and a big line kit.Where can I find them?
Old Apr 30, 2007 | 03:46 PM
annabelle's Avatar
FASS it.....
Old Apr 30, 2007 | 05:29 PM
bdewey's Avatar
Can order the Walbro set-up with big line kit from this website. Put Walbro in my truck and it has been great. Also by ordering through DTR you help support website.
Old Apr 30, 2007 | 07:28 PM
zulusafari's Avatar
I second the Walbro setups. I am biased, though, since I have one myself.
Crazydave's Avatar
How much do you want to spend? Vulcan performance has there big line kit for 115 with out a pump it relocates the stock one to the frame rail , Glacier diesel performance has a big line kit with Walbro pusher pump for around 399 and a fass is like 600. I have not seen complants about any of them. Good Luck
Old Apr 30, 2007 | 09:03 PM
Ph4tty's Avatar
A oem carter pump from napa and a big line kit from Vulcan worked pretty good before I went mechanical =P
The line kits can be found here: http://www.vulcanperformance.com/
or Geno's is always good http://www.genosgarage.com/
Old Apr 30, 2007 | 11:33 PM
PaulDaisy's Avatar
Lift pump upgrade option are endless. Let your budget, creativity and herd instinct guide you
FASS, Walbro, relocate kits, DIY anywhere from $100 to $600.
-P
Old May 1, 2007 | 08:48 AM
Joe Diesel's Avatar
I did a vulcan big line & relocte kit with a stock carter pump, 16psi @ idle now its easy to change if need be plus its a great price for this set up
Old May 1, 2007 | 09:27 AM
CJ's Avatar
CJ
I just did a walbro/big line kit from wideopendiesel.com last week and could not be happier.
CJ
Old May 1, 2007 | 10:57 AM
Tiger Rag's Avatar
Copy and pasted from another post I made.
IMO,
Best option: Helix 2 cam and 12 valve lift pump.
Better option: Glacier Walbro or Fass
Good option: Pusher from BD, Bulldog or build your own with a relay and Holly Blue.
The "Good option" will cost you in the neighborhood of $120 for the make your own to $225 for the BD or Bullydog. The "Better" option $6-800 maybe a little less, not exactly sure. The Best will cost you 2 to 3 hunded more than the Better option.
The "Best option" is a fix it and forget about it with the 12 valve lift pump. Plus you get the benefit of a more air flow through you head and more low end torque. It's a few more $, but it will be the last time you have to think about it.
Old May 18, 2007 | 04:17 PM
duramjames's Avatar
I did the vulcan big line relocate kit and I got the campaign pump from cummins for $63.00 I now run 14-15 at Idle and 9 atWOT with juice set on 5 its great thanks for your help
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
Redleg
Oct 14, 2005 07:45 PM
yomitch
Oct 30, 2002 06:30 PM
bkay
Oct 7, 2002 05:19 PM
