lower intercooler boot??
Old Oct 24, 2006 | 08:19 AM
v8440's Avatar
I've been running 45 psi for some time (until my transmission bit the dust) through stock boots and clamps. My truck has 270,000 miles on it. Sounds like a problem with the pipe in your case.
Old Jan 15, 2007 | 03:52 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Bringing new life back to this thread. Lately my trucks been seeming down on power. I got gobs of fuel psi new air filter and new filter filter about 5k ago with the new lift pump. I am either leaning towards my clutch is slipping when I get up on it or there is a boost leak some were because it seems to be that the turbo is laggy and never been laggy before and a slipping clutch would cause that or possibly my lower intercooler boot is coverd with oil and may have a whole in it as its seem to be rubbing on the fender and from doing my reasearch alot of them had this problem.?????? But normal driving i cant hear it leaking over the motor but if its a small whole it would not make that much noise but would it cause it to loose power
Old Jan 15, 2007 | 04:12 PM
mkrenn's Avatar
My factory HX leeaked oil and started blowing boots! May want to check that if anyone is blowing them!
Old Jan 15, 2007 | 04:59 PM
DTR's Cow Boss
Its not leaking any oil its just the bottom lower incooler boot has the greese and grime of the road on it and its dirty so i cant visably tell if its got a leak. I am goin to start a thread on what i found this afternoon wich in my thinking was my problem
Old Jan 15, 2007 | 10:41 PM
600 Megawatts's Avatar
Muted User
I can tell you from experience that if a leak is large enough to cause a power-loss you can HEAR IT !!! It positively rips particularily when you are along side a car on the passenger side and you get on it. You can't miss the sound of all that air rushing out. Mine had a 1" long slit, and I was down about 8 Psi and you couldnt mistake the sound if you were deaf.
If you cant hear it, you dont have a big leak.
And you cant miss the clutch slipping either, your RPMs will shoot right up, but the truck doesnt !!!! lol
Kp
Old Jan 16, 2007 | 09:00 AM
DTR's Cow Boss
So 600 after further inspection all of the clamp on the boots all of them were loose i was able to get about 1/4inch of a little mroe out of each of the clamps tell they were tight again. So would that intell a small enuff leak not to be able to hear it? I am getting a boost elbow somtime this comin weekend and if my van aaken is not working it should throw a over boost code but if its working then ill have no code. I dont think the clutch is slipping hard but its coming oh well its coming out of there next october soon as i sell some calvs. I should have done the boost elbow a long time ago from what I have been reading because I had not followed up the va with more boost after give a touch more fuel
95black2615
Oct 8, 2008 03:34 PM
dumptruck200
Apr 25, 2007 11:03 AM
windkid4
Jul 9, 2005 09:06 PM
WTTD
May 28, 2003 08:03 AM
