low end grunt
Old Jan 4, 2006 | 08:27 PM
Barefoot88's Avatar
low end grunt
I'm running the comp untapped and rv 275's is there any way to get some bottom end power pulls good in higher rpm's .thanks guy's
bad 1 ton
Old Jan 4, 2006 | 08:38 PM
Big Deezul's Avatar
hot rod VP adds a serious low end punch
Old Jan 4, 2006 | 08:45 PM
Barefoot88's Avatar
big diezel,
yea i know but thats a high ticket item but i could go ahead a tap the pump and when it breaks I can get a hrvp and a dtt when you need it you have no choice
bad 1 ton
Old Jan 4, 2006 | 09:41 PM
ratsun's Avatar
I never ran one but I hear the Catcher is what you seek.
Old Jan 4, 2006 | 09:46 PM
Dusty Ratcliff's Avatar
unplug your map sensor, will give you more off idle fuel, w/or w/out the wire tapped, might be somethin to try, Dusy
Old Jan 4, 2006 | 10:03 PM
TORQUE's Avatar
Try tapping your pump wire, this will help minimize it somewhat. Or you can try to find an original "CATCHER", or wait until the new "Smarty" controller comes out, this WILL give you the low end power you're looking for.
Old Jan 4, 2006 | 10:07 PM
BigBlue's Avatar
Get a DTT vb and tap the wire. I ran the 275/Comp/DTT valve body combo for a few months and I put down 371hp and the tranny never slipped on my once. Plus it had TONS of low end power. If the road was wet I could put it on 2x2 and roll into the throttle and the rear end would spin a little before it caught.
Old Jan 4, 2006 | 10:51 PM
Ocmechanx's Avatar
Unplug ur map sensor first, if thats not enough for ya, go with the catcher, it'll give ya all the little vp pump can, just be ready for some smoke
Bryan
Old Jan 4, 2006 | 11:41 PM
TORQUE's Avatar
Unplugging Map sensor will give more fuel, but "CATCHER" does a lot more than just fueling off the line.
Old Jan 5, 2006 | 12:26 AM
yfz450guy's Avatar
where is the map plug at and what are the long term good and bad?
Old Jan 5, 2006 | 11:19 AM
high country's Avatar
driver side 3/4 of the way back on the motor just follow the wire on your comp....if you don't have one don't unplug it or it will just throw codes.
Old Jan 5, 2006 | 05:05 PM
Barefoot88's Avatar
you guys think you could use the catcher with the comp in ez mode or would it be best to tap the wire been reading about timing issues with comp I dont hotrod to much but i tow 10 to12 thousand pounds i just need the low end power
bad 1 ton
Idaho Guy
16
Apr 28, 2009 02:17 PM
smoknblack01
Mar 29, 2008 11:02 AM
johnstra
22
Feb 27, 2006 10:48 PM
TorqItUp
May 14, 2005 12:37 AM
sdgunslinger
Apr 1, 2004 08:30 AM
