Heavy hauler needs more grunt
Old Mar 28, 2008 | 11:41 PM
smoknblack01's Avatar
hey guys. I have been thinking about putting a edge/attitude in my 01 with a set of small injectors. From what I can tell from everyone in here its a good setup for people who tow light. But I tend to tow very heavy in the summer Hauling hay and equipment around montana. Truck and trailer across the scale see's 30,000 plus often. Will the setup run to hot for me. If so what would you suggest. I don't race or hot rod around alot. Any info would be much appreciated thank you..
Old Mar 29, 2008 | 12:18 AM
nike's Avatar
DISCLAIMER: i KNOW VERY LITTLE......
I set of rv275 and an adjustable box like the juice w/attitude set on stock should keep you cool while towing heavy...
Old Mar 29, 2008 | 12:35 AM
What are the rv275's rated at for hp? I don't know much about injectors or anything else for that matter. Thanks for the advice.
Old Mar 29, 2008 | 01:49 AM
Krob's Avatar
RV275 are a and i am not quit certain but someone will correct me if i am wrong. RV275 were the stock injectors for 5.9 going into RV they are rated at 275 hp at the flywheel compared your ho 245hp. Does that make any sense.
If i was you id look towards Quadzilla's Adrenline instead of J/A. THe adrenline is probably the best box out on the market. Look through the performance threads youll find alot about it. THe pulse witch hooks up to the adrenline will give you all your gauages and a lot of extra features.
Either one of these with a flip of the switch can be turned way down or off. Making it possible for you to pull real heavy.
Some one will chime in that knows more then i do.
Old Mar 29, 2008 | 02:38 AM
That makes perfect sense Robin Thankyou. So the rv275 Is only 30 hp more than my injectors, dosn't seem worth the money but what do I no So is stock going to be the best for towing heavy??
Old Mar 29, 2008 | 07:52 AM
J Lent's Avatar
Just get a quad Adrenaline & later add some RV275. I tow heavy 26-27000lbs combined & have tried almost every box/programmer on the market, the Adrenaline is by far the best.
Old Mar 29, 2008 | 11:02 AM
Swamp_Donkey's Avatar
If you don't get the juice with attitude, get a pyro so you know for sure what your temps are. I am a little suspect of the pyro accuracy on my juice with attitude on my 04.5.
lovinCTD59
Dec 23, 2008 11:10 AM
johnstra
22
Feb 27, 2006 10:48 PM
Barefoot88
Jan 5, 2006 05:05 PM
TorqItUp
May 14, 2005 12:37 AM
sdgunslinger
Apr 1, 2004 08:30 AM
