lots of oil on the ground!
well i went out yesterday and found a big puddle of oil under the truck
i started looking around to see if i could see where the main leak was and it was everywhere. so i called a buddy and took it for him to look at and he said he doesnt think it was the kdp but maybe a front main seal. i dont kno it is leaking from the front of the motor.
I'd get the KDP kit from eg Piers Diesel because the front engine oil seal is in there and you will have peace of mind after doing it. If I recall the pricing correctly the seal was about 40-50 US$ at cummins and the KDP kit was about 10 US$ more than the seal alone. (And the instructions in the kit alone if you don'T have the repair manual are well worth it)
Just my 2c
AlpineRAM
Just my 2c
AlpineRAM
Kill two birds with one stone, get one of these kits>
http://www.tstproducts.com/index.asp...PROD&ProdID=64
If after removing your fan bearing mount you find a crack in your gear case this is what you need to do http://cumminsdatabase.com/read.php?id=111
well i got the truck from my step dad about two years ago and didnt kno what a kdp was untill i got on dtr. which was not long ago. i hope it is just a seal but if it is the case well i guess **** happens. ok ill look at the vacum pump tomorrow im going to wash all of the oil off and see if i can find out where it is coming from. thanx for everyones help it is greatly apreciated
well i think it is the vacum pump that is leaking. i dont kno if it is a seal or what but im prety sure that is what is leaking. but i ordered the kdp killer friday so it should be here soon and when my buddy returns from the bush in alaska in a month he is going to help install it. thanks for every ones help.
I've heard of KDP hitting some EARLY 24V engines, but never a 2001. It's kinda like a 53 block-- very rare to see in later 24V trucks.
KDP isn't the first thing I'd look at for a 24V puking oil-- I'd look at vac pump seals or turbo oil drain and such.
jh
jh
