looking into a performance chip
Old Oct 4, 2011 | 11:27 PM
cjk2000's Avatar
I have a 2000 cummins 4x4. The only thing done to it right now is a diamond eyes 4" to 5" exhaust, and a blue chip injector pump. I'm looking to install a perfromance chip/tuner. I've heard the smarty tuners are really good. I do some towing of campers with my truck. other than that its just normal driving. I am also going to upgrade the injectors this winter. I was thinking about going with 90lbs? any input you guys would have is awesome. Thanks!
Old Oct 5, 2011 | 07:00 AM
j-fox's Avatar
Go with a SMARTY and 275 RV injectors.
You should see better mileage and will feel real power improvements.
BTW, injectors are rated at hp improvments not in lbs /hr.
Old Oct 5, 2011 | 09:55 AM
DodgenIt's Avatar
Is your blue chip pump stock hp or bigger?
If it's stock, your turbo should be ok for enough air. But night get a little hot with injectors and a chip or programmer. If it's bigger then stock, you'll want to be thinking about turbo upgrade with chip and injectors.
I'm a fan of the juice with attitude cause of all the gauges it has as xell as on the fly power changes.
Old Oct 5, 2011 | 03:33 PM
cjk2000's Avatar
its the stock replacement pump from blue chip, not the special x one.
Old Oct 5, 2011 | 06:31 PM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
I stack Smarty with EZ.....been EZ on it until I put in the BD Converter, VB and Pan I bought.
gergthegreat
Dec 30, 2008 09:19 PM
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
cowdude
Feb 19, 2003 06:20 PM
