Looking for a Cummins, Help.
Old Aug 29, 2006 | 11:44 PM
BDS's Avatar
BDS
What year(s) should I be trying to locate? I know about the code "53" cracking problems but I'm not sure if it was 99-2000 or 99-2001.
I am looking for a Cummins to build up for everyday driving and Lots of fun. I am leaning towards a 24v so that's whay I'm posting it here. But I have not completely made my mind up to not go with a 12v. I really would like the adjustability the electronics give me on the fly. I will be sled pulling regularly but also towing my 8k travel trailer about a dozen times a season. This is for my Fummins conversion so my slate is clean and I can pretty much do whatever at this point.
I will be "building" this engine before the install...Studded, cammed, o-ringed, head work, injectors, twins.....This will be bolted to a NV5600.
Brent.
Old Aug 30, 2006 | 07:00 AM
crobtex's Avatar
You would probably be happy with either one. Granted, the "on the fly" changes for the 24v is a plus.
As far as the 53 block, mine has 185k on it with no problems. But, I'm not near the power levels you're looking for, so it might be a good idea to pass on the 53.
Old Aug 30, 2006 | 08:18 AM
one54ton's Avatar
Tough decision. 12v are much cheaper and you dont have to deal with Vp44s. 24v are nice due to the adjustability. Id go 24v since I have one.
Old Aug 30, 2006 | 11:52 PM
BDS's Avatar
BDS
Thanks for the input. I have read that the Gen III Cummins has the strongest block yet. Is this true? I wouldn't mind doing a Gen III Fummins since my friends 05 runs real good with his TST box. He is awaiting a clutch from Haisley and a S300 from Schied. Then I bet she'll run!
Anyways back to the topic. What years did the code "55" block exist? Is this the strongest block for a 12v or 24v build up?
Thanks,
Brent.
Old Sep 1, 2006 | 11:28 AM
BDS's Avatar
BDS
Any input on what I asked above?
Also, there are a few on Ebay right now...One is a 2001 so is this a "53" code block?
Thanks,
Brent.
Old Sep 1, 2006 | 02:15 PM
dieselrob's Avatar
53s are found in 98 - 01 but they thin out in the 01s. For the amount that you see have cracked i wouldnt loose sleep over it. I have a 53 and dont care. im gonna bomb as far as i can. I think it might of been Jim Fulmer (not quite shure) had a 700+ 53 for a long time and had no problems. If ya find a good price jump on it. I would look for an 03 cr motor they are really starting to shine these days.
Old Sep 1, 2006 | 03:15 PM
BDS's Avatar
BDS
Thanks Rob, I have another thread going on the 12v forum similar to this one but more 12v oriented. I do thank you for the info on the correct years to look for and the advise on the 53 blocks. Is the code 53 block only a 24v thing or did the early 98 12v have these blocks aswell?
Brent.
crazyjunk99
Cummins Conversions
Oct 9, 2013 07:12 PM
F1B3R
Jan 2, 2011 08:59 PM
theIntlEggrole
Jul 16, 2007 05:53 PM
bob95065
39
May 7, 2007 09:48 PM
dctoner
Feb 9, 2004 02:55 PM
