Light Upgrade Complete!
Old Feb 16, 2008 | 09:41 PM
  #31
newconcorddodge's Avatar
s-cube
I bought those same fog lights at wallly world, they come with a bracket on them. When i put them on i just screwed the screws into the plastic molding on the inside after i lined them up which took a little elbow grease.haha Was a little tricky, but i probably only spent an 1 to hook everything up considering they did not come on the truck.
Old Feb 16, 2008 | 10:14 PM
  #32
nirion's Avatar
I also got those fog lights at walmart. I modified the bracket a little and screwed into the plastic. They work pretty well for $20.
Old Feb 17, 2008 | 01:44 PM
  #33
haloman's Avatar
Originally Posted by s-cube
I like the looks of those fog lights. How did you mount them?
I took the stock fog light off the bracket and turned the bracket around on the walmart fog and screwed it into the stock bracket.
Old Feb 17, 2008 | 02:03 PM
  #34
Deezel Nate's Avatar
I put a set of those on my truck like you did about 2 years ago. Still working fine.
Originally Posted by haloman
Here is a cell phone pic of the $20 fog lights I got.
Old Mar 3, 2008 | 01:28 PM
  #35
barngal6's Avatar
Bue Tint/ Radiators
Will the fogs still fit with my coolers (radiator-things for transmission, etc)
behind the grill? Looks like a tight fit, anyone with heavy duty tow
package done it?
Also, Like Buckshotram,
The fog lights I found at Walmart look really blue in the box.
I thought the pic you posted looked blue too...
But they don't have a blue hue when they are off?
(couldn't tell if it was the blue bulb they come with
or some kind of blue coloring in the reflector...
Or is it just blue cellophane in the packaging?
thanks Haloman for this thread, this is a super desirable upgrade and you've
really made it seem do-able. Great thread!
Originally Posted by Buckshotram
I like your headlights and foglights. Are your foglights the cyberwhite or something like that from wallmart for like $40. My friend bought those except they were real blue. I like how yours look in the daytime. Any Nighttime pics of the fog lights?
Old Mar 3, 2008 | 01:36 PM
  #36
haloman's Avatar
package done it?
Thanks for the Comment. i am no mechanic and I would have trouble if it wasn't plug and play which all the upgrades are very plug and play.
The fog light bulbs do look blue but give off a white light that matches the silverstar bulbs I have in the headlights. To me they are a good white light with no blue that I can tell and are not blinding white like the HIDs in the newer BMW vehicles. The ones I posted run $20, I have no experience with the other kits they sell. These fog lights should fit just fine as they attach to the stock fog light mounting bracket they way I have them and actually stick out a bit farther so you shouldn't have any clearance issues AFAIK.
Old Mar 3, 2008 | 02:01 PM
  #37
barngal6's Avatar
Well that does it then..my next upgrade! thanks again Jenni
Old Mar 17, 2008 | 12:03 PM
  #38
haloman's Avatar
Did you get anything ordered Jenni? Post your results.
Old Mar 18, 2008 | 10:33 AM
  #39
justme-'s Avatar
Barngal- report back how it goes- the heavy duty tow package was not available factory with fogs because of supposed clearance issues from the thicker stuff up front.
Looks good Haloman!
Old Mar 18, 2008 | 10:37 AM
  #40
haloman's Avatar
Thanks for the compliment
Old Mar 19, 2008 | 02:09 PM
  #41
barngal6's Avatar
[QUOTE=justme-;2002834]Barngal- report back how it goes- the heavy duty tow package was not available factory with fogs because of supposed clearance issues from the thicker stuff up front.
[QUOTE]
Sorry, its going to be a while before I do this, my "next" mod...
just had nerf bars, a bed box and posi-loc installed
(and a new starter)
so I'll be waiting a little while before I do the lights and the fogs.
BUT I will post when I do it (unless you try it before me)
Jenni
Old Jul 2, 2008 | 09:57 PM
  #42
David B's Avatar
Anyone tried just ordering the whole enchilada from LMC? Lights, bulbs, harness and all?
Old Jul 3, 2008 | 05:08 PM
  #43
haloman's Avatar
You could but it would be more expensive.
Old Jul 6, 2008 | 12:28 AM
  #44
Vaughn MacKenzie's Avatar
Question
Originally Posted by Lil Dog
. . . With the fogs, I cover mine with Armorshield coating to keep them from getting pounded by rocks. Works well even though I only spent the $40 on them as well.
What exactly is Armorshield and where do you get it. . . googling Armorshield brings up a lot of different companies by that name but none look like the right one.
Old Apr 2, 2009 | 08:05 AM
  #45
haloman's Avatar
So an update on this for you guys. I guess when I said "complete" it was nt exactly true. Back in Decemeber my Walmart fog light mount broke on a road trip so I replaced those with some stock fog lights from Ebay. Then after riding in a truck with a set of HID bulbs, I had to have a set. Installed a "Flashtech" 6000K Hi/Low kit last night. WOW!!!!!!!! It is brighter and throws more light on the road than I thought possible with the aftermarket housings. Very pleased with the initial results. No pics yet as we finished late last night, but will update.
