Leveling kit ?
Old Aug 4, 2004 | 07:08 PM
OldSmokey's Avatar
Leveling kit ?
When I installed my leveling kit I noticed that the frount axle is sticking out the drivers side more than the passangers side. Im guessing because of the stearing linkage. What is the best and cheapest way to move everything back to normal. Thanks Joel
Old Aug 4, 2004 | 08:27 PM
phox_mulder's Avatar
It's not because of the steering linkage, it's from the trac-bar.
Trac-bar is a specific length for the stock suspension height.
Raise the truck up, track bar pulles the axle to the drivers side.
The only fix is an adjustable track bar.
It isn't enough movement to warrant a relocation bracket like the 4inch and up lifts have.
I noticed the shift when I had my 2" spacers, but noticed it less and less each day.
Don't know if things were settling, or if I was just getting used to it.
phox
Old Aug 5, 2004 | 06:01 AM
I SPEED's Avatar
Here's a thought...when I put the spacer lift in my TJ, I unbolted the trackbar from the axle and drilled another hole about 3/4" towards the drivers side and reattached the trackbar there.
The axle sits centered under the Jeep.
Now if I could figure a way to center the rear axle things would be perfect.
HTH
Doug
Old Aug 5, 2004 | 06:19 AM
wagontrain131's Avatar
HTH
Doug
That may be fine on a 4000 # Jeep. I'm not going to do that on a 7000# truck.
That's just me. It's your truck, do what you want.
Kyle
Old Aug 5, 2004 | 07:09 AM
Joe Diesel's Avatar
Even better than using a 2" block to level the front end my mechanic suggested changing the front springs to 1 ton springs and that will level it off. I'm gonna change the springs this fall and post some pics.
sgtdiesel
25
Jun 26, 2012 02:37 PM
dodgeboy59td
26
Dec 31, 2002 12:05 AM
UTAH
32
Dec 11, 2002 11:47 AM
Fishin2Deep4U
Dec 10, 2002 07:34 PM
j
17
Nov 10, 2002 07:57 PM
