larger aftermarket turbo housings
Old Feb 8, 2003 | 02:50 PM
PourinDiesel's Avatar
Re:larger aftermarket turbo housings
At your point of modification you will not benefit from a larger turbine housing.
Although when you go above your current level, like larger injectors and Edge Comp, I would suggest a 14 housing for your HX35.
If you want to run stage 3 injectors at their peak effeciency I would suggest a B1 turbo or Piers 40, stage 4 injectors I would suggest HX55, hx40/18 or small twins.
The more fuel you run through your engine, the more exhaust volume is created/increased and to relieve that you will need larger exhaust/turbine housings to help with this.
12cm2 @ 350hp
14cm2 @ 400hp
16cm2 @ 450hp
18cm2 @ 500hp
These are generalized numbers listed above, and my observations.
I would suggest with 14cm2 housings and larger to move up to an HX40 to help move more compressed air (larger impeller diameter)
--Justin
UnrulyNFS
Mar 5, 2008 07:37 PM
DODGE 92
Sep 22, 2005 06:19 PM
Beast2B
Mar 27, 2005 08:38 AM
Jambbii
Aug 3, 2004 02:49 AM
Hired Gun
Jan 1, 2003 02:39 PM
