Killer B-2 Question
I just got my comp back upgraded to drag comp, adding mad ecm, and i am planning to switch to mach 5's all at the same time, i am also looking to switch turbos during this transition period, would a killer b-2 be a good turbo for my set up? I had a thicker HG and studs installed last month.
With Drag Comp and Mach 5's, I would think you need all the air you can get in a single turbo ....Killer B not enough. Maybe even a PS66?
But, I'm sure Doug can steer you right! Give him a call.
RJ
RJ
undecided
Feb 12, 2003 10:13 AM
