Keyless Entry Install?
Old Dec 25, 2005 | 07:53 AM
Txwelder's Avatar
Anyone install their own Keyless Entry, Remote Start, Alarm setup? I got a PROSTART 3300 for Christmas and was wondering if anyone had any info about it. Thanks.
Old Dec 25, 2005 | 09:29 AM
infidel's Avatar
Never installed a Prostart but have installed a few other brands.
It is very time consuming, mainly finding the correct wires in the tightly wound bundles under the dash. Would take even longer to find the correct wires unless you have a factory service manual. This is even when the install instructions had the correct wire colors availible on the remote's website. The ones I've installed had over twenty different connections to make.
Expect to spend a minimum of eight hours for the install.
Old Dec 25, 2005 | 09:53 AM
Geico266's Avatar
If you can find a professional installer in your area it's money well spent, and all the functions will work.
I hate crawling under the dash.
Old Dec 25, 2005 | 11:07 AM
Txwelder's Avatar
I dont let many people touch the old girl but if I would end up doing more harm than good I guess I should let a Pro handle it.
Old Dec 25, 2005 | 11:38 AM
Geico266's Avatar
I hear ya, but when it comes to this stuff I'm all thumbs. Plus they guy who does it everyday can do it in his sleep. You don't have to reinvent the wheel. Just makes sense to me to have a pro do it.
Old Dec 26, 2005 | 01:17 PM
BlueRam01's Avatar
txwelder,
I've installed a couple of remote starters and a keyless entry on my vehicles. They were/are all Bulldog Securities units of which I have not had a bit of trouble with since the first remote start/keyless entry on my 96.
If you decide to do it yourself I'd recommend getting the FSM for your truck so you have accurate wiring diagrams. For my 3 installations I then listed the wire colors and functions so I would know exactly where all wires were connected. I did keyless only, on my 01, and the lock wiring colors were the same as the 96 but I ran thru 'em anyway just to be sure. All splices are soldered w/ heat shrink tubing. Also working on a nice day helps. It was below freezing the day I did my 96 but I had a bullet heater which helped a lot. My other install was the Bulldog remote starter only on my wife's old 92 Mustang which work great, also.
My main point is that preparation is the key. Don't just dig into the job because you might try to rush through and mess something up. Knowing the steps ahead of time will also make the job go faster. Just leave plenty of time and all should work out OK.
Old Dec 27, 2005 | 10:35 AM
Txwelder's Avatar
Well, as I am installing the remote start, keyless entry and the alarm I am going to get a few quotes for install. I dont want to burn something up or have to start over after install and have something not work. Thanks for the input.
Kevin
joelayan
Feb 19, 2009 08:02 AM
mkeanglorldo56
May 30, 2007 11:10 PM
GlennRMK
Apr 11, 2006 08:49 AM
Haulin_in_Dixie
15
Sep 6, 2005 06:08 AM
c5r
Apr 24, 2003 05:18 PM
