can anyone help with python keyless entry install
Old May 30, 2007 | 11:48 AM
mkeanglorldo56's Avatar
Exclamation can anyone help with python keyless entry install
another problem. i am puting an aftermarket alarm with keyless entry in my truck cuz it would be nice to have keyless...im not sure if my truck ever was keyless cuz i bought it used and it was never said or i never got a remote. but anyway the polarity of the doorlocks are reverse polarity from what i understand. so i wired the relays in like this diagram says........ http://www.commandoalarms.com/reversepolaritylocks.pdf
and when i hook up the motor wire to the relays the fuse pops and ive checked my wireing so many times and looked for other diagrams but i just have no idea whats wrong can anyone help me??
Old May 30, 2007 | 12:37 PM
74dart's Avatar
I have the wiring diag from when I put mine in in the truck if no one else chimes in before I get home tonight i will give it to you. It is diffrent from what you may think it should be.
Old May 30, 2007 | 04:54 PM
thanks so much!!
Old May 30, 2007 | 06:54 PM
juicedbusa02's Avatar
are you sure you have your switch and motor wires correct? try switching those around take your unlock relay and switch the wires on 87a and 30 then take your lock relay and do the same thing ... that should work ... let me know if i can help i do this stuff alllllllllllllllllllll day long thanks
Chris
Old May 30, 2007 | 11:10 PM
cool ill try that thanks
joelayan
Feb 19, 2009 08:02 AM
edwinsmith
Sep 22, 2007 02:05 PM
GlennRMK
Apr 11, 2006 08:49 AM
Txwelder
Dec 27, 2005 10:35 AM
Dieselhead
May 13, 2003 12:44 PM
