k & N air filter
Old Nov 1, 2002 | 09:20 AM
TEDHRS's Avatar
k & N air filter
Does anybody use it and is a good thing to get? What kind of improvement does it provide?
Old Nov 1, 2002 | 09:56 AM
TEDHRS's Avatar
Re:k & N air filter
okay, but what if did not want to take the stock air filter box out?
Old Nov 1, 2002 | 10:09 AM
TPilaske's Avatar
Re:k & N air filter
I use a K&amp;N, put it in the first week I got the truck. Gives you a good whistle, couldn't tell you if it increased performance or dropped EGTs any because I did not have gauges that soon! Other than that, I like it! ;D<br><br>Tony
Old Nov 1, 2002 | 10:37 AM
dodgeman01's Avatar
Re:k & N air filter
80k on my k&amp;n. Works great. only had to clean it two times. I really have no complaints. Happy that I don't have to buy a new filter for a while.
Old Nov 1, 2002 | 10:38 AM
Lil Dog's Avatar
Re:k & N air filter
K&amp;N has had some problems with the gasket seal thickness to fit in the box... Actually all brick filters have this problem. So if you do install one, be careful to ensure a good seal.<br><br>Try AFE, same as K&amp;N with better quality and fit. (AFE is the original guys from K&amp;N)...<br><br>J-eh
Old Nov 1, 2002 | 10:43 AM
cr1998's Avatar
Re:k & N air filter
[quote author=Cattle Hauler link=board=4;threadid=6491;start=0#60474 date=1036164845]
Get a BHAF, it allows more air flow and increases the turbo wistle. Took my stock air fliter box out and added the BHAF, I love it
[/quote]
CH, I know your sig says stacks coming soon, but do you still have your muffler &amp; resonator now? If so, even with them you could tell a difference in the turbo whistle? Can't wait to get mine installed tomorrow. What about the silencer ring, do you still have it? Tried to take mine out last weekend but the snap ring wouldn't just pop out like a lot of the posts have said. I was concerned about prying too hard on it. Didn't want to slip and damage the turbo. Anyway, have a large time at dyno days this weekend and say hey to everyone for me.
CR
Old Nov 1, 2002 | 11:08 AM
Dodgezilla's Avatar
Re:k & N air filter
I have a K&amp;N with no silencer ring and it sounds cool as #$%. I still have my complete exhaust and you can still hear the turbo spool up just fine. I had removed my muffler and resonator but I'm a wuss and just thought it was way too loud. You can, however, really hear that turbo with straight pipe...<br>I did not see any performance improvement with the K&amp;N and also don't have any guages to tell you if my EGTs dropped. I have always run K&amp;Ns on my vehicles and have never really noticed any gains except in my wifes 01 Mustang GT. She actually told me she felt a difference without me even asking her.
Old Nov 3, 2002 | 07:55 AM
HC's Avatar
HC
Re:k & N air filter
I know some like the K&amp;N, but here's an alternate opinion:
I had a K&amp;N RE-880, but didn't like the oily residue and saw high Si in oil analysis until I added the foam prefilter. I've switched to a MHAF (AH-1141) with an Outerwears pre-filter and I'm happy with that.
Unless you have fueling mods (boxes or bigger injectors) I don't think you will need or see any real performance gain from different air filters.
Finally, especially if you're still under warranty, you should at least consider this:
http://www.cummins.com/na/pages/en/p.../faq/index.cfm (Look at question #24)
The BHAF and MHAF, although not &quot;approved&quot; by DC, are at least made by Fleetguard, so I think you could argue for your warranty being OK if the issue came up.
Old Nov 3, 2002 | 10:44 PM
cr1998's Avatar
Re:k & N air filter
What is MHAF and what is the difference in it and the BHAF?<br><br>CR
Old Nov 3, 2002 | 10:58 PM
cr1998's Avatar
Re:k & N air filter
Just installed the BHAF this weekend. That was something that concerned me. Didn't stop me from installing it though. Guess the yearning to hear that turbo whistle was too much. ;D I thought I read on a post somewhere here that the NAPA 2790 had the mesh on the inside. Anyone know for sure?
Cattler Hauler, is your new BHAF a Fleetguard or NAPA? If NAPA, does it have the mesh on the inside?
CR
Old Nov 4, 2002 | 04:47 AM
CRobey4393's Avatar
Re:k & N air filter
CR,<br>I had a NAPA 2790 and there is no mesh inside.<br>Chuck
Old Nov 4, 2002 | 10:19 AM
Bob Beauchaine's Avatar
Re:k & N air filter
If you use the K&amp;N on the 94's and up what I've seen some people do is to use a bead of grease on the gasket edge to help seal out all air. I understand that this works quite well. I have run K&amp;N on my 1st Gen for about 140,000 miles. The first time I cleaned it I followed directions and let it dry naturally - over night. Since mine is a daily driver I re-installed my old filter - this is when I decided to buy another K&amp;N so I could just swap them out and clean the dirty one at my leisure. I could feel the difference. I change them out at every other oil change - 12,000 miles. I have supported my K&amp;N useage with oil analysis at every oil change. The analysis test results are as good today as they were with the first analysis. <br>You might want to check with Damlier-Chrysler about warranty issues - I seem to remember that they don't approve of K&amp;N on panel filtered trucks.<br>Bob
