Juice EGT Temps?
Old May 6, 2006 | 10:47 AM
efrantz's Avatar
Juice EGT Temps?
I Have The New EDGE Juice And While Under Throttle My EGT WIll Just Sky Rocket! I Have A 4" Straight pipe And An Intake When Esle Can I Do To Cool This Thing Down? What Is A Safe Temp And How Long Can It Be Run At High EGT? Is A 1/4 Mile To Long? Thanks
Old May 6, 2006 | 10:53 AM
scottsjeeprolet's Avatar
What are the temps? What are your boost numbers at these temps?
Might want to check for boost leaks, check the wastegate is still hooked up.
Did you install the boost elbow? If not you might want to do that, it will raise your boost numbers.
good luck
scotte
Old May 6, 2006 | 10:57 AM
efrantz's Avatar
The Temps Will Very But If I Just Keep On The Gas They Will Just Keep Rising! I Will Check The Boost And Get Back With That Number. What Numbers Should I Be Getting? (EGT's And Boost) Thanks
Old May 6, 2006 | 11:58 AM
GlennRMK's Avatar
I don't have mine tapped yet, but EGTs seem really good on level 1x5. Seems like it takes a lot to get to 1050. I have 4" and an AFE air intake.
From what I've read, keep it around 1150-1250 sustained(towing) or for short bursts, it really doesn't matter.
Old May 6, 2006 | 12:14 PM
bryceepoo's Avatar
I don't know if I'm high or low, but cruising down the freeway at about 70 on flat ground I tend to run in the mid-700's and with any slight grade it'll go right up to 850. I don't really ever get past 1000 without trailering something though. Bryce
Old May 6, 2006 | 01:30 PM
Hey Brice that sounds about right. My numbers are about the same.
they say don't keep it above 1200 for any amount of time.
Glenn is your probe preturbo? Did you install the boost elbow? It will help keep your boost up and temps down.
Old May 6, 2006 | 07:39 PM
RJF's Avatar
RJF
Hmm, I've got a dinky HY35 and I run about 625* on the highway empty with the Juice on basically any level.
It takes a full throttle run to hit 1300* at about an 1/8 mile.
I have 5" exhaust and a stock intake and filter. No J-hook either.
Old May 6, 2006 | 10:00 PM
GlennRMK's Avatar
Yes, I have the boost elbow and the pyro is pre turbo
My temps are the same. Figured this average. Actually seem lower then my VanAaken.
Old May 6, 2006 | 11:48 PM
BigBlue's Avatar
1250* is the max you can hold sustained. Anything over that you can only do in short bursts (1/4 mile, 10-15sec, yall get the drift). With the boost elbow you should be hitting 30-35psi.
northern puffer
Dec 23, 2003 09:00 PM
8secondride
Mar 9, 2003 09:27 PM
8secondride
Mar 1, 2003 11:21 PM
