Juice edge, stock turbo, only 25 psi boost?
Old Apr 2, 2008 | 09:31 AM
vp_mopar's Avatar
what should it be putting out? Is this right? i hear people putting out 40 psi! stock? If not how to i fix it?
Casey
Old Apr 2, 2008 | 09:41 AM
dzlfarmboy's Avatar
If it's a auto you will need a j hook or a turnbuckle to keep the wastegate shut, but if it's an manual you need to put a boost elbow in the front of the compressor housing on the turbo.
Old Apr 2, 2008 | 09:42 AM
JIT's Avatar
JIT
Did you use the boost elbow? If not then theres your problem. It should have come with a boost elbow that helps keep the wastegate shut for higher boost #'s.
Old Apr 2, 2008 | 10:23 AM
haloman's Avatar
You will need the boost elbow for your 2000 model.
Old Apr 2, 2008 | 11:39 AM
Adam3291's Avatar
Daniel is right, all the 98.5-00 trucks will need a boost elbow for the HX35. It gets a little complicated when you go to the 01-02 trucks, in those year models the manual tranny trucks have the HX35 so it takes the boost elbow but the auto trucks will need a J-hook for the HY35 they have since the wastegate line isn't rubber. Hope this helps.
Old Apr 2, 2008 | 02:08 PM
newconcorddodge's Avatar
I put in the elbow that came in the kit, and see up to 33-34.
But haven't tried to do anything to hard, trans needs work, and I thought the most output with my stock turbo was 35ish.
Old Apr 2, 2008 | 05:24 PM
vp_mopar's Avatar
that little brass 90 degree elbow? if so then yes. I dont No where it goes though?
Casey
Old Apr 2, 2008 | 06:03 PM
Big Blue24's Avatar
Brass elbow goes on the turbo compressor housing. You will need a little hose clamp 1/4"-5/8" clamping ability if Juice did not come with one.
Just replace the brass elbow on the turbo just like you see in the picture below.
This elbow limits the amount of boosted air that can flow through the hose to open the wastegate. With elbow, you should see 30-35 psi boost with the Juice set to kill.
Attached Thumbnails Juice edge, stock turbo, only 25 psi boost?-eebay2.jpg   Juice edge, stock turbo, only 25 psi boost?-eebay1.jpg
Old Apr 2, 2008 | 07:02 PM
vp_mopar's Avatar
yup there was one that came with it, dunno how i missed it, instructions told me exactly what to do, psi went up to 32, good deal. thanks everybody.
casey
PowrStorkthsRam
May 12, 2007 11:27 PM
sqrl$$
Competition / Pulls / OffRoad
Feb 26, 2007 09:15 AM
Conn
Dec 6, 2006 12:40 PM
razor6
22
Jan 20, 2006 03:43 PM
ckennedy
Sep 29, 2004 05:06 PM
