Jammer stg5 EGT's
Jammer stg5 EGT's
Wondering wether to get the stage fives or not. What can I expect as far as egt's with the stage5 sticks pulling 20,000#? Dont mind not being able to run the edge juice w/attitude just need to be able to pull that kind of weight occaisionally and don't want to melt it down. So when i'm not pulling I can run with the box and run quick.
What smarty # were you on? Lately due to the heat and humidity I've had to slice it back to #3 or #5. ANd that's unloaded
I can hit 1500* empty on a 0 to 60 run with juice on # 2. Now it has been around 100 degrees out and I'm at 5000' elevation. On # 1 on the juice, I can't get over 1300* no matter what I try. I have never towed that heavy so no idea what that would be like.
I CAN hit 1500* empty as well if I want to. When I'm towing I ease into the fuel and I don't really have any heat issues. It will smoke a good bit upon takeoff.
I have a PS62/12 sitting on the workbench though
Hopefully that will clear up some of the smoke.
IMO, you're going to have a hard time pulling that much weight even with the box off with 150's, at least up hills.
Your key word is "occasionally", IMO. May require lower gear...higher rpm's and box low or off! But worth it to play hard...if not towing regularly.
A PS62/14 (due to 6 speed) would be my next step.... would be a BIG difference!
RJ
xOmertAx
20
Feb 17, 2007 09:52 PM
Ocmechanx
Jan 14, 2005 10:10 AM
