Jammer 3's or 4's
Old May 4, 2007 | 05:59 PM
pmtg's Avatar
Originally Posted by trbdsl96
pgilles- That does seem a little odd. But is the power there?
I also wanted to ask everyone how did you buy your jammers? Just nozzles or full injectors? If nozzles did you get them tested? How do your trucks idle?
Jason
the power is there. as too exactly how much im getting, i dont know. im by no means an expert so i cant jump in a truck and say 'those feel like 150hp injector'. theres no doubt the truck gets up and goes alot better, and the first couple weeks always put a smile on my face but now im itching to tap the Comp wire....wanting more already !!! (waiting to get the new clutch in before i tap the wire). also, a slipping clutch will feel like less power so theres a few variables going on before i can criticize the nozzles.
the tough thing with injectors is you cant turn them down or off like you can with a downloader or module so if heat becomes a concern you need to learn to drive again or throw money at more air.
i did the nozzles and was antsy to put them in so i did not pop test them. BUT i will be pulling them out again to have it done!! truck has ~170,000 miles so it could be considered routine maintenance as well. they idle just fine, maybe a slight hiccup here or there but nothing continuous.
also, i sent you a PM Jason
~Pat
Old May 4, 2007 | 06:02 PM
99globalwarmer's Avatar
nozzles are cheap and easy.l buy the nozzles
Old May 4, 2007 | 06:18 PM
O791challenger's Avatar
I have stg 3 nozzles in mine, it idles smooth no prob's yet. I installed them myself, could not be easier. The only prob I have ran into is I have a small leak somewhere in my fuel system now, I just have to track it down. Other than that I like them alot, considering most will bash them.
Josh
Old May 4, 2007 | 07:13 PM
trbdsl96's Avatar
99globalwarmer- I think you miss read my signature The Banks stuff is on my OTHER truck! It's a 96, my wife is enjoying it at the moment. I have no desire to change anything on it at the moment, I love it. These injectors are for an 02, my daily driver.
Old May 4, 2007 | 07:19 PM
trbdsl96's Avatar
O791challenger, pgilles- Glad to hear you both like your Jammers. If I get just nozzles they will be getting tested for sure. Thanks for the info Pat.
Jason
Old May 5, 2007 | 10:06 AM
hamilton71801's Avatar
I also bought stage 3 nozzles and am very pleased with them. I didn't get them tested because I was in a hurry and figured I would try my luck which turned out to be pretty good. After a hard pull/run they will get a little loopy but it normally clears up pretty quick. As far as EGT's, I haven't had an issue yet whether pulling or farting around.
Old May 5, 2007 | 05:34 PM
trbdsl96's Avatar
Thanks for the input hamilton71801. Aounds like the heat won't be too much for me.
Jason
xOmertAx
20
Feb 17, 2007 09:52 PM
TDIDog
Jan 17, 2005 09:19 AM
Ocmechanx
Jan 14, 2005 10:10 AM
4x4
Nov 21, 2003 03:23 PM
Dieseldude4x4
Feb 13, 2003 12:57 PM
