its time for timming
Old Jan 12, 2004 | 12:47 PM
dodgeman01's Avatar
I'm going to get my truck timmed this weekend. I know most people say to go to 16* but I was wandering how much of a chance would I be takeing if I went to 17* or 18* ?
DM01
Old Jan 12, 2004 | 01:18 PM
banshee's Avatar
With 370s and a stock head gasket I'd say somewhere in the 18-19 degree range would be best.
Old Jan 12, 2004 | 01:37 PM
Don M's Avatar
DTR Advertiser
I agree with Banshee
Old Jan 13, 2004 | 02:30 PM
dodgeman01's Avatar
So is nobody going to try to tell me different? I have had 16* forced into my head but if Don says 19* then I feel comfortable
DM01
Old Jan 13, 2004 | 03:00 PM
bulthisl's Avatar
DM01
That is what I was going to suggest with that baby pump.
: Eddie :
Old Jan 13, 2004 | 08:10 PM
SmokinDodge12V's Avatar
Nineteen would be pushing it on a stock head gasket especially if your running high boost numbers, but I do know of some guys running over 20 on stock head gaskets, but trust me a blown head gasket is no fun.
Old Jan 14, 2004 | 08:36 AM
dodgeman01's Avatar
what do you consider high boost? I can hit 40psi with my hx-35. I plan on getting my block o-ringed but not until next fall ($$) I'm buying a sbc DD street clutch next month so that is going to take a chunk out of the bank.
Old Jan 14, 2004 | 09:10 AM
bulthisl's Avatar
Arron,
Check your pm's over yonder.
: Eddie :
Old Jan 14, 2004 | 09:54 AM
dodgeman01's Avatar
Originally posted by bulthisl
Arron,
: Eddie :
Over yonder is that the code word for it now
DM01
Old Jan 14, 2004 | 07:06 PM
If you stay at 40 lbs of boost you might be ok at 19 degrees if you take it easy until you get the o-ring like not pushing more than 10-15 lbs of boost while the engine is still cold, what DD clutch are you going to get.
Old Jan 15, 2004 | 01:25 AM
Got Smoke?'s Avatar
In other words Aaron, it wouldn't be wise for YOU to go with that much timing! I can hear that phonecall already!
Old Jan 15, 2004 | 11:11 AM
dodgeman01's Avatar
I'm going with the DD SBC street clutch. should be getting it here in a few weeks.
DM01
Old Jan 15, 2004 | 11:49 AM
DeereDiesel's Avatar
I have mine set at a hair over 19 and 370's with no probs. Set my wastegate at 40psi. It can run more than that but I dont really want to.
carty
Old Jan 16, 2004 | 11:30 PM
dodgeman01's Avatar
welll just got back from what I thought was going to be a different running truck. I found out my truck was already timmed to 19* Checked it two times and came up with the same measurement of 7.0
I don't know what could cause my miss above 3k rpms. I checked the check valve with one that was known to be good and it runs the same. could it be a lift pump?
DM01
Old Jan 17, 2004 | 07:32 PM
Jim Fulmer's Avatar
If your timing is at 19 then I'd rule that out, low timing and more fuel on little pumps usually pops a bit at high RPM, as far as fuel pressure put a guage on it and see if the overflow and lift pump are fine then you can go from there.
Jim
